  • 3 weeks later...
Cheers :)
1996 Nissan Skyline R33 GTS-T Series 2
170,xxx kms
5 speed
304rwkw (411hp) on 18psi with Caltex E-Flex
Driveline
rb25det
Hypergear ATR43 G3 turbo 0.82 rear housing
Nismo 740cc injectors
Tomei fuel pump
Greddy 600*300*76 intercooler kit
Yellow Jacket coil packs
3” custom cat back exhaust
3" high flow cat
3" JJR bellmouth dump pipe
Apexi air filter
Apexi Power FC & hand controller
NPC heavy duty organic single plate clutch
NPC billet flywheel
Suspension & Body
SkylinesAustralia ‘Sydneykid’ Bilstein/Whiteline spring & shock combination coilovers – awesome ride quality
Whiteline rear cradle bushes
Rear guards rolled
Wheels & Tyres
Front – Work Emotion CR Kai 18 * 8.5 +30 – Pirelli P-Zero Nero 235
Rear – Work Emotion CR Kai 18 * 9.5 +20 – Nitto Invo 255
Work blue anodized wheel nuts w/ lock nut
Work hub rings
Electronics
Sony head unit – Bluetooth/USB
JL Audio 6” split front speakers
Blitz id3 electronic boost controller
Blitz id power/speed meter
Defi Boost Gauge
Defi Oil Temperature Gauge
Defi Gauge Controller
LED dash backlighting
Phillips Crystal Vision headlights
Cyclops immobiliser
Holy smokes....nice car!
I want a ride in this baby. Would be a handful!
You should edit your post to remove the security details on the car. Never can be too careful.
Cruise it is.
Just had one last weekend :)
Haha thanks bud,
When we catch up will take you for a spin - it's surprisingly not an intimidating car to drive.
Noob question but how do I edit a post? :wacko:
Yea Nick that would be great what time? And where about? How do u want for it man?
I can leave now if you're keen man I just got home from work. Um $10 just to cover fuel in the Corolla will be fine man :)
Oh shit you're in here now. This was a nice neighborhood :P
I wouldn't say nice as much as id say tolerated by the powers that be but yes, ladies hold your panties until we say so Luke may or may not now own [hushed silence].... A skyline.
*stage gets covered in underwear*
DID WE SAY YOU COULD THROW THOSE!?
  • Like 1
haha you're a funny bastard Nick.
Yea Chris been On the forum for a little bit just haven't posted anything as I haven't had anything useful to contribute (probably still don't haha) excited to meet up with some of the peeps on here :)
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
