  • 3 weeks later...
Cheers :)
1996 Nissan Skyline R33 GTS-T Series 2
170,xxx kms
5 speed
304rwkw (411hp) on 18psi with Caltex E-Flex
Driveline
rb25det
Hypergear ATR43 G3 turbo 0.82 rear housing
Nismo 740cc injectors
Tomei fuel pump
Greddy 600*300*76 intercooler kit
Yellow Jacket coil packs
3” custom cat back exhaust
3" high flow cat
3" JJR bellmouth dump pipe
Apexi air filter
Apexi Power FC & hand controller
NPC heavy duty organic single plate clutch
NPC billet flywheel
Suspension & Body
SkylinesAustralia ‘Sydneykid’ Bilstein/Whiteline spring & shock combination coilovers – awesome ride quality
Whiteline rear cradle bushes
Rear guards rolled
Wheels & Tyres
Front – Work Emotion CR Kai 18 * 8.5 +30 – Pirelli P-Zero Nero 235
Rear – Work Emotion CR Kai 18 * 9.5 +20 – Nitto Invo 255
Work blue anodized wheel nuts w/ lock nut
Work hub rings
Electronics
Sony head unit – Bluetooth/USB
JL Audio 6” split front speakers
Blitz id3 electronic boost controller
Blitz id power/speed meter
Defi Boost Gauge
Defi Oil Temperature Gauge
Defi Gauge Controller
LED dash backlighting
Phillips Crystal Vision headlights
Cyclops immobiliser
Holy smokes....nice car!
I want a ride in this baby. Would be a handful!
You should edit your post to remove the security details on the car. Never can be too careful.
Cruise it is.
Just had one last weekend :)
Haha thanks bud,
When we catch up will take you for a spin - it's surprisingly not an intimidating car to drive.
Noob question but how do I edit a post? :wacko:
Yea Nick that would be great what time? And where about? How do u want for it man?
I can leave now if you're keen man I just got home from work. Um $10 just to cover fuel in the Corolla will be fine man :)
Oh shit you're in here now. This was a nice neighborhood :P
I wouldn't say nice as much as id say tolerated by the powers that be but yes, ladies hold your panties until we say so Luke may or may not now own [hushed silence].... A skyline.
*stage gets covered in underwear*
DID WE SAY YOU COULD THROW THOSE!?
  • Like 1
haha you're a funny bastard Nick.
Yea Chris been On the forum for a little bit just haven't posted anything as I haven't had anything useful to contribute (probably still don't haha) excited to meet up with some of the peeps on here :)
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
