Check your cooling system, Clint.
Only a matter of time before you blow a gasket or something.
Oil temps shouldn't be high with just regular driving even with the ambient temps we're getting.
The old 180 sat perfectly fine in 40degree heat not moving with the aircon on...until she started overheating after a thrash and then the Koyo went in :P
Rad flush and fresh coolant + thermostat will get her all nice and purty again ;)
Ah that's good...yeh the oil does creep up a bit on these hot days man :/
Oh nice! That must've been one of the two resident 35's we have here. Man imagine driving that thing around all day knowing you got so much f**king power :O
Thanks guys. Coolant temp never moved, was just oil temp got higher than normal.
Saw a gun metal/dark purple 35 pulling onto Margaret on Boxing day. Was totally jello
I don't know how accurate the R34 gauge is for oil. It could be out of whack.
However, if it is correct, then elevated oil temps can be linked with the inability of your cooling system to keep temps in check.
The nissan water temp gauge is the most inaccurate thing ever. Once it indicates things are hot, you've cooked the motor :yes:
I was lucky enough to catch my gauge in the process of getting hot...it was only 3/4 of the way but by then, even my intercooler cold pipe too hot to touch. Managed to crawl the old girl home with the heater on full whack to help with temps.
New coolant and thermostat (optional) is cheap. Cheaper still that there are mates out there willing to help.
1 weekend without alcohol is all it costs LOLOL :ph34r:
I'll be owning one of these after this weekend HA ;)
Moving into our new place at Laidley on thursday, guess I'd better start trolling this thread more. Hopefully I can get the 32 fixed and come on some cruises soon. Stupid ceramic turbos.
Sounds good bro, I'm in the next town over at Gatton. if someone waves at you from a Red and Black 33 that'd be me :)
Finally moved in and internet connected, getting car moved out here next week so I can start ripping it apart ready to replace dead bits. If I see an orange and black 33 I'll be yelling 'abomination' and pointing.
You have just become...
One of us. :D
Now sign up as a member :P
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
    • I must preface my comments with a general expression of ignorance. I have no specific knowledge of these NA automtaic things. I can only assume that the "steering wheel button" is for enabling the tiptronic controls. Wierd that it would even need/want a button for that... But anyway.... Was the car previously tiptronic? Did you put a new cluster in as part of all this?
    • Regardless, it doesn't seem wise especially on RBs to actually chase MBT. Timing scatter is the big one on stock CAS, even if that's fixed overshoot is worse than undershoot.
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
