I was going to ask you guys to head out to the KMart meet on Saturday 6pm.
Amanda will be there with her family (if you remember her from our last run).
That's her gig and her dad's a regular.
Where do we meet up? Tbar HQ?
Sounds good. Am doing an oil change on Saturday. Meet up at mum and dads place at around 6?
Got the urge to begin ripping the turbos off the R, got most of inlet side done and am beginning to wonder if a high mount single is a good idea. This metallic spaghetti system is really annoying lol.
High mounted singles are good. Especially if you get pulled over. Then your car will be off the road again.....
Whichever way you go, do it quick so we can get more cars on the road when we do our little cruises :)
We really need to add a bit more variety to our sausage fest :ph34r:
Just keep in mind money/ecomical wise, under 500hp is best for twins, over 500hp is best for single - golden rule for turbo upgrades. Have a real hard think about how much power you want vs how much you can afford as there are many hidden traps to fall in to with this shiz.
I personally would upgrade twins and keep the car at a daily 400hp. Then, from experience, I would throw money at further reliability items and longevity stuff while keeping that same power level. Doing it any other way ends in tears, especially once you start making over 450hp.
Haha you'll be right - it's actually one of the easier things to do on the car. Just take a heap of photos for your first go and put aside a weekend for it.
Also be sure to replace your head studs, nuts and all your copper crush washers. Yes, you can get by without doing that but you risk getting oil and coolant leaks if you "re-crush" copper washers that already have been crushed out once.
I replaced all my mani studs/nuts (engine and turbo-to-manifold flanges)
As far as removal goes, here are some tips:
- remove bonnet and park under good lighting
- drain all your coolant and oil
- remove all your IC pipework that covers the turbos and group it on the floor with associated nuts and bolts
- remove your front pipes
- remove the exhaust side cam cover (you will need to so you get better leverage with the 12mm spanner for the mani nuts)
- start on the front turbo first, loosen all nuts off equally...you'll see that the more you loosen the nuts off equally, the more room you get when you're able to wobble the turbo around.
- take care with the metal oil and water lines....they can take a bit of bending and manhandling but don't push it.
- have a heap of cheap 12mm spanners / ratchet spanners on stand-by for the mani nuts...buy the flattest profile ratchet spanner you can afford. Use the cheap 12mm spanners to bend to shape for some of the more awkward mani nuts - you'll see what I mean when you get to them haha
Took me about 8 hours to do last time with engine in car. (including swapping all the gear over on the turbos once they're out...water lines, brackets, heat shields and the dump pipes). Some peeps say that it's easier to do with the motor out too...and I dare say it would be, but then that's a heap of extra work too. All much of the muchness really.
But yeh, just be sure to keep all your stuff you remove together. Keep nuts, studs and pipes together in piles etc. Every time you remove a major part, take a photo. I did this for mine but hardly needed them.
Edited by tommis85
Lots of stuff I would have never considered, thanks dude. Been using the little tool kit I keep in the car but I'm gonna have to go to my parents place in NSW and get my big tool box and jack before I can do much more.
Haha yeh, there're a lot of different ways you can go about it and everyone has their own preferences...the last time I did it things came apart and went together quite easily actually.
One other thing that you could do while the stuff is off is port match the manifolds. The stock ones were deliberately "miss-matched" by 7-10mm to de-tune the RB26. You may have to take them to a shop for this or get some aftermarket ones. A bit of a gain to be had there with the new turbos ;)
Also, while you have the front pipes off get a larger diameter flex joint welded in to them that's not smaller than the pipe dia like the stock one is. I had this happen on mine - no wonder the rear turbos struggle a bit!
And...while we're talking exhausts, you should really get new dump pipes for yours. The R32 items are shocking, the R33's are a good upgrade, the R34's are fantastic (welded item, not cast).
So yeh, port match, flex joint (or new front pipes) and new downpipes will see you get the most out of your brand new turbos. How's the rest of your exhaust? Do you have a higher flowing cat?
It's got a 3 inch trust system, including front Y pipe. I binned the compliance cat and put a massive one on it. Think it's a Metalcat. When the turbos get replaced I'll probably do the dumps too, since they'll already be unbolted and won't be any extra labour.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
