Can't multiple quote on iPad.
Shirts should be in. We want steak in a venue threat won't hang me from the rafters for lunch.
But of a cruise. A bit of fun.
Chris, love you log time. Chris, get f**ked.
Both Chris can argue as to which Chris they are. :)
Meringadan pub does a good steak. No need to argue, everyone loves Chris Rogers because of the great work he does with skylines
... Yes well he called me a bogan no mouth hugs for you mr rogers ;)
If we're talking this weekend, if something gets organised you can count me in. If I can con one of my mates into driving ill bring up the abomination
tony you have totally lost me..
Apologies, have spent the last 2-3 weeks either inebriated or getting inebriated. My communication skills are rapidly declining.
Mike's trying to organise this for the weekend following Easter, does that work for you?
Felt so good getting the Gtr for the maiden voyage today hopefully meet up without everyone for a cruise very soon
Weekend after Easter a bunch of us Brissy guys will be heading out to meet you guys and hopefully drive some roads.
Sounds good that's my weekend off so be keen as to go for a cruise hopefully get a fair few skylines out
Good work ;)
But I bet the first 10 people to put their names down will all be cops :D
I'm not a cop...
What we need to do is get a huge cruise organised on here and then just rock up with one single donut van, nothing else :) You'd probably get tasered and bashed and cavity searched but it would be worth it :D
.. Nick... Where are you Nick.. Got a job for you. :D
I vote Nick does it :whistling:
    • Nissan/Pitwork is fine stuff. HKS is just marketing wank. I personally wouldn't do the idler if it is already new. If it looks and feels fine, it is fine. But as D says - it's cheap to add it to the job. The water pump ditto. Even more so. If it show no signs of problems, then it is nearly new - leave it.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
