Fair enough. But shit hey, when you're up close and personal with the paintwork you sure notice a F-load of scratches, chips and dents! I swear there wasn't a single mark on the old girl 6 years ago!
I don't need to be up close and personal these days to notice imperfections haha
Ok kents, so we still gonna do this today? I need to syphon some fuel and pick up Brian.....Brian I'm gonna need your addy at some stage my phone's out of cred/plan.
Would much prefer the meeting time to be 12 as I'm half seedy
Yeah its still on
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
    • Aside from the fact it is likely fuel related if it is black, the symptoms otherwise sound like worn valve stem seals. Oil gets past the worn seals when the engine is off and burns when the engine starts. If it happens on deceleration while driving (puffs of white smoke) that is another valve stem seal symptom because oil gets sucked form the head into the combustion chamber under vacuum with the throttle closed. They can be replaced in the car if you have some way to keep the valves closed while working (eg compressed air into cylinders) but is much easier with head off.
    • Alright, fair enough. Expected as much. Possibly, yes. However the kit is apparently not including every single hose and it is out of stock too.
    • I sourced my silicone hose kits from Just Japanese. Their current link is what I posted above but supplier might have changed over the decades.
