the repco on Herries Street are having a little show and shine today. Will be a couple of skylines there. If any of you Toowoomba guys are driving past drop in for a bit of a chat thumbsup.gif
What time is this starting/finishing?
hi every one in ((((((((((((((((((Toowoomba))))))))))))))))))))) im going to sell my95 s1 r33 matt black :wub: with orange wheels cuz i move to UAE for long time so i don't need this car more
the car done 99.700KM low KM at this time i spend around 25000$ on this car new tyres .rego until 2/2012
just 13000 for it
I'll be there on the Sunday also, going in a mates RX2 tho
ah righto, yer im heading down in my mates GT so yer my skyline wont even be there.... (among the 3000 other ones that will be lol)
Bit quite in here as of late. Jambo was crap compared to previous years. Cannot believe they gave show and shine awards to a Ford Focus and a VZ Maloo ute
a vz took out a jambo show an shine.... for shame....
Yep, It was a shocking turn out, way to many holdens and fords, few years time Jambo will be open to all cars the way its going
First of all, WOW a VZ won? There goes the neighbourhood!
Hey Toowoomba people, just bought my first skyline and thought I would introduce myself here.
If your interested we have a cruise happening this coming Sunday, your more then welcome to come along. Just PM for more details.
The invite goes out to all you Toowoomba guys if your keen for a cruise PM me thumbsup.gif
im in man, keen as to show off the "fully sick" vinyls lol :P, but in all seriousness if anyone wants any stuff done involving vinyl wrap hit up steve from wrapture styling 100% happy with the stuff he did (now just to fix this subborn clear coat problem, and buy some black rims lol)
what rims you looking at? I was thinking about the black te37 style from option one.
Yer theyd be sick. Im interested in any rims that are 17's or 18's, 8 inches or wider, and have a 4x114.3 stud pattern/PCD. if anyone one has a set PM me :)
Great, just when I was thinking of getting vinyls, the only other grey 33 in toowoomba gets em. Well you win that race hey?
Better put my money into engine mods :P
meh, just win the race on the black top - shouldn't be a problem hey Nick :whistling:
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
