Who fixed it for you?
She got a new lancer, it was about time the oldies settled on what car they were getting. All the questions the old boy was asking me was driving me insane
Pretty sure you can figure this one out, Chris.
Guard needed some massaging, intercooler brackets needed straightening, and some plastic welding was done. All corroded/broken bolts were either removed or drilled out with new ones put through. Definitely wasn't a straight forward job but it got done one weekend. Paint was done by someone unknown to me but it was certainly better than the paint previously on there.
There...I've given you one very distinct clue already as to who done most of the work as it happens to be his specialty :)
Man of many skills - some of which I'm just beginning to discover.
Lancer evo X bathurst?
Think its afm from what I can find out pretty common problem not sure how reset ecu other than scan tool I've got one to do obd2 but not obd1
Just disconnect the battery and tap the break a couple times, turn lights on etc, turn key etc etc....to bleed the system of all power. I also left my old liner disconnected for a couple hours to make sure she was well and truly in reset mode when you fire it up the next time.
When I first do this to mine it won't idle... Second start is fine
Well now you'll have to give it a chance to learn the engine again. I had to do this for my GTST when I put the intercooler on and also when I put the pod on. There's actually a procedure to *helping* the eccs learn...like, a set way that you should drive it so that the computer can fine tune all it's tables (seeing that all engines are different but the computers all have the same maps etc etc)
But yes, if it's chuggy/surgy I'd go over all your vacuum lines, pressurised pipework and all your sensors. Give it all a tighten-up and clean with contact/carb cleaner - your engine will love it (even if it doesn't fix that particular problem)
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
