I'm going to move a motion to kick you from sau at the club meeting, just because you won't Lakeside with me.
I don't even know if ill have my car back by then :rant: .... Also dosent look like I'm going to have time for my cam before the drag day :(
Oh right lol...that sucks balls man. Your skyline should be ready just in time then :D
Yep sucked big sweaty hippy balls, was dark and cold and bullshit :angry: .... And to make matters worse i then had to walk to my other job. IM NOT DESIGNED TO DO THIS MUCH CARDIO!!!! :(
2 weeks till opens today!!!! :D
