I have had the luck of owning some R32 Gibson cams. I had them cam doctored. Thought I would share some information as this forum has helped me quite a bit. I never installed them as they did not run a std base circle. These were machined from nissan blanks. They did run different cams for different tracks, along with a sump specific to the track. No idea what circuit these were for.
Inlet
261
9.54mm
326.4 lobe center
Exhaust
273
9.74mm
326.4 lobe center
Tolerance: 1/2 thou
May give you an insight into my own cam choice. I didn't stagger my cams as I have plenty of exhaust flow from the 3ltr.
Matt
Edited by BoostdR
https://www.sau.com.au/forums/topic/361140-gibson-r32-gtr-cam-specifications/
The base circle was 1mm under(30mm). I would just be grabbing some JUN Cams(as i have done)
JUN
IN 264 9.7 EX 272 9.7
Std 31mm base circle
No Cam lobe refuge machining
Can use with Std springs but i use Tomei Type B-9500rpm(type A-8500rpm max) which are heavier than what come with the JUN kit.
or
HKS
IN 264 10mm EX 272 10.2mm
What we found with testing JUN Cams
264 264 gives more power and better response than std cams, pretty smooth idle
264 272 gives more power than above and better spool than below, slight lump
272 272 less 500rpm response more power, little lumpy
Matt
Edited by BoostdR
272 272 less response more power
Can you give a quick overview of your specs? You mentioned 3lt but what head/manifolds/turbo/power etc.
How much did the doctoring cost?
Doctoring was $40
My specs are:
rb32
89mm CP pistons sleeved and sonic tested
264 9.7 IN&EX 0 and 0
Tomei type B springs, std retainers
Ported head 1mm over Supertech valves(short turn, bowl area only)
HKS GTRS's (port mactched exhaust housing)
Tomei Dumps-3" front pipes-3.5" exhaust-5" internal Muffler
Z32's
ARC 100mm intercooler
E85 (Liberty)
1.1mm block restrictor, Mines Baffles
6 boost Manifolds(dyno'd with chinese stainless)
Reinmax Oil pump with std springs 3.5 bar warm idle, 7.5 bar max
Howards Rods
8.55:1 Comp
1mm Cometic head gasket(good squish)
ARP throughout
Matt
Have a look at this link for cam testing on a 3SGTE. The reason I bring this up is the results we got from our own testing on a Rb26/30 was similar in curve, rpm, duration, lift and relationships apart from the 272IN and 264EX which we haven't tested and our 264/272 combo resulted in 10kw gain up top over 264/264, torque was also 150rpm later.
Cam test
Matt
Edited by BoostdR
JUN
or
HKS
Matt
Hey Matt,
So just to be clear, the above results was with the cams set at zero?
Cheers
or
HKS
I have this exact setup in my car already haha.
Will have to think about whether it's worth changing.
Interesting to see these results as they go against the grain with a lot of people.
Good work Matt. :thumbsup:
I agree cams with around that duration just seem to work really well on a mildish setup
Im on 260 10.2 270 10.2 tomei's.
After cam timing was setup these cams are very very lumpy
2.6LTR
twin 2530's
410awkw on 98
467awkw race fuel
We pieced this combo together in 2004 and to this day i cant bring myself to change a single part of the setup it destroys other gtrs with big single's and 150+hp..
Nice info matt...
2.6LTR
twin 2530's
410awkw on 98
467awkw race fuel
Nice info matt...
Great results from 2530's. What boost are your running? Additional specs would be great.
Matt
Lots of $$ invested in the head is helping alot:
Jhh ported head/built 2.6
1mm+ IN 2mm+ EX valves
Good multi angle valve job
Tomei cams as above
Extrude honed stock manifold
2530's
Almost maxed 800cc sards
Dual nismo intanks
Sorted my suspension issues out recently taking it out saturday should go bottom 10's hopefully..
2mm oversized exhaust valves? Damn, don't hear of that often. Surely that's the maximum that fits in there.
Which actuators are you using?
Fantastic result, I bet it's fun!!!
Jealous for sure
This is a Txt from my engine build on 2mm+ IN 3+Ex:
Yep it would fit in the chamber. Better if it was a 88mm bore( sleeved block) No point though as I can't remove that much material in the port or I'll find water
Actuators went from hks to 19 and now to 25psi units exhaust side must be getting close to the limits.
Quite excited to get it on e85 should be faster again with the extra torque from the fuel and push closer to 500kw if the turbos hold up..
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
    • The only way to make that better is to weld on some bozozoku tips up past window height and roll with the cool kids.
    • I'd want an even MORE side on view. More or less you want to make sure the outlet is actually square with the outermost part of the bumper. Or you end up getting soot all over your bumper from your hektik exhaust. In any case, it looks pretty close. I think the way to fix this is probably more of an overhaul at an exhaust specialty shop if you want tips that are rounded off or sit nicely with the bumper but have proper clearance and don't move - Probably more of a redesign than a quick fix. I've pencilled in my own exhaust with its own various problems, pinholes, PITA fitment, and other issues and can see myself going to a shop and saying "JUST DO THIS BUT BETTER?"  Which is gonna work better than any more small fixes. I'm gonna chime in here officially with "from an outsider perspective this exhaust looks fine so this is self OCD probably" (which I also suffer from)
    • Reminds me I really need to install that HKS oil cooler I bought years ago.
    • It be 40°C outside lately. 10W60 is a good idea here. Well, certainly 10W50.
