Car looks tops Russ and good work on the shakedowns :thumbsup:
Man that wing is high! I look forward to seeing it in person and good luck with the whole WTA thing.
Thanks Ant.
Well shakedown 2 didn't go too well. Only got 2 sessions in at PI on saturday.
After first session we noticed that the turbo to manifold gasket is leaking.
After session 2 I had to stop as coolant was pouring out from the front of the head. We suspect it will be a welsh plug. Blew coolant through the bay and over the windscreen while going round hayshed! ;)
On the upside it is good to find these things now rather than at Superlap. Bit more work to do.
On the list is.
1. fix above problems
2. New greddy intercooler so we can have more power
3. New rear subframe as the one in it now is cracking around the mounting points :O
4. New hardrace camber arms front and rear and traction arms.
5. AO50's and alignment at traction tyres.
6. Screamer pipe.
so yeah.. Bit to do in the next few weeks!
Wow how did the subframe crack?
Give us a yell if ya need a hand getting it ready :thumbsup:
Running semi's for 5 years on a subframe that had crap welds. Looks like it had been repaired poorly in the past. It actually cracked right next to the weld.
It's been repaired by Mat but a whole new subframe would be a good idea.
very nice build cant wait to see this thing in action at WTA
Thanks mate.
stick a s14 or 15 subframe one in as tey fixed the rear roll center :) (with offset solid bushes)
I haven't heard of that? Please elaborate... Is it a straight bolt in? Diff, hicas, arms?
they dont fix the rear sub frame they dial out the anti squat which r32 and s13s have to much of. some of the circuit r32s have done it down here with measurable gains. aprox 1 sec a lap on a 60sec track.
you could also use a r33-r34 subframe. its not just a bolt in between them thoe. the diff mounting is the biggest problem. hicas and all arms are the same the only difference being the lower control arm mounts to the subframe differently.
if you have a look in the last few pages of my build thread i think there is some good info on it. if not i have a ton of pics of the differences between the differnt subframes that will show you what i mean.
Cool. I'll stick with what I know for now but might be something to look at in the future.
You know Newton runs an R34 rear sub-frame in Big Red right Russ?
Yeah I did hear that. I'll have to ask him details about it. Won't be doing anything like that yet. That means new diff etc...
Thanks guys.
We did some work at the workshop today. 12 solid hours.
Found the problem welsh plug that came out. What are the chances! Random thing to happen! So we replaced a heap of others to be safe.
Found the exhaust leak. Pretty damn obvious! manifold will be getting machined so it doesn't happen again.
Other things... Front camber arms have gone in. They are Hardrace via just jap. Seem to be good things.
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
