Hey Russ if you get stuck i have a r32 subframe sitting at home if you get desperate, needs bushings though, a couple of them are cracked/leaking. Otherwise its had an easy life. Most of the rear suspension is still bolted to it though, but can be quickly ripped off with impact wrench. Also various gtr/gtst diff housing and centre/gears.
Well shakedown 2 didn't go too well. Only got 2 sessions in at PI on saturday
You and me both....although for diff reasons. I went to Sandown and was gentle on the motor for the first two sessions checking knock and temps etc...then the rain hit and out went my chance of a PB :(
No matter as I enjoyed the entry to the front straight ;) and I will live to fight another day!
Good luck with the prep/fixes.
I'm in open class.
Haven't tested a GTR cooler yet coz of the need to modify piping. Lots of time has gone into piping so don't wanna have to redo it if there is a better option. Thanks for the offer though.
well i have just upgraded to a 4" thick core for my car so i have the old "hybrid GT spec" branded 600x300x76 (3" in and out) bar and plate core spare.
though if you are looking for a tube and fin design thats not much help.
Ok. What power has it 'flowed'? what's the length end to end? How much?
Put a STD GTR cooler in it Russ! Best flow kw wise and they actually allow air threw to ur rad which is a big problem with all these crappy aftermarket tube and fin/bar and plate coolers!
Just did similar upgardes to my thing, High mount and GTR cooler now making an easy 320kw and running 30 degrees cooler at Sandown!
Seems like you did okay at winton today Russ, you feeling better prepared for Super Lap now?
Yeah mate. Very happy to get a 1:33.7 at winton. Consistent 1:34's with a turn in understeer problem is great. understeered wide at turn 6 (last right kink before the cleavage) and hit a saw tooth ripple strip. Need another alignment now. It wouldn't turn right properly after that :(
