Hey Russ if you get stuck i have a r32 subframe sitting at home if you get desperate, needs bushings though, a couple of them are cracked/leaking. Otherwise its had an easy life. Most of the rear suspension is still bolted to it though, but can be quickly ripped off with impact wrench. Also various gtr/gtst diff housing and centre/gears.
Well shakedown 2 didn't go too well. Only got 2 sessions in at PI on saturday
You and me both....although for diff reasons. I went to Sandown and was gentle on the motor for the first two sessions checking knock and temps etc...then the rain hit and out went my chance of a PB :(
No matter as I enjoyed the entry to the front straight ;) and I will live to fight another day!
Good luck with the prep/fixes.
I'm in open class.
Haven't tested a GTR cooler yet coz of the need to modify piping. Lots of time has gone into piping so don't wanna have to redo it if there is a better option. Thanks for the offer though.
well i have just upgraded to a 4" thick core for my car so i have the old "hybrid GT spec" branded 600x300x76 (3" in and out) bar and plate core spare.
though if you are looking for a tube and fin design thats not much help.
Ok. What power has it 'flowed'? what's the length end to end? How much?
Put a STD GTR cooler in it Russ! Best flow kw wise and they actually allow air threw to ur rad which is a big problem with all these crappy aftermarket tube and fin/bar and plate coolers!
Just did similar upgardes to my thing, High mount and GTR cooler now making an easy 320kw and running 30 degrees cooler at Sandown!
Seems like you did okay at winton today Russ, you feeling better prepared for Super Lap now?
Yeah mate. Very happy to get a 1:33.7 at winton. Consistent 1:34's with a turn in understeer problem is great. understeered wide at turn 6 (last right kink before the cleavage) and hit a saw tooth ripple strip. Need another alignment now. It wouldn't turn right properly after that :(
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
