:blink:
I'm confused. All sounds interesting and stuff but you guys need girlfriends :)
Jokes aside would you mind running those calcs on my new wing? What dimensions do you need other than the basice shape? Can you go by a photo?
Any chance taking me for more spins in this thing?
Sure. It's still got straight pipes on it so maybe a quick spin round the block lol. Car is now at the factory in ringwood. Problem is that it's wheelspin city as tyres aren't up to temp. Kinda pointless but you'll still like the experience haha
Russman how are you going for rear traction?
I went for a track night last Thursday and had nothing... My car was over steering and wheel spinning with any hint of throttle when not in a straight line. Has rear camber at 0.75 and toe 1mm in each side!
Whay tyres have you got? What susp?
My car is very settled in the rear now. I am runnig 265 AO50 Semi's though. It puts the power down very well but my power curve is very progressive. It doesn't ramp hard at all.
Check out my video's and you'll see how well it's working. Nothing fancy with suspension settings. Springs are 6kg/mm I think and shocks are adjusted to soft.
Looking forward to this weekend. I am so going to T-Bone your car through the flip flop. You better pray you are in a different group Boy! :whistling:
haha! Buy a raffle ticket. You might get a hot lap :P
haha! I've got one of those, you know it actually turned out to be cheaper to have one than be single and hit the pub every other night :P... plus i love her, of course :ph34r:
Anyway sure thing. basically i need the upper surface area of your wing... so length times width. and a couple of good photos so i can approximate what shape the wing is... really what needs doing, to be accurate, is to measure the chord length, nose radius, maximum thickness, camber of the curve etc. etc., then you can work out exactly what wing shape you have and use the proper lift coefficients.
but approximating is so much easier =P
im feeling a bit zombified at the moment, just finished a 128hr 10 day week. but thats what i can remember at the moment.
cheers, Rowdy.
p.s. Roy be nice!
I'll measure stuff at some point and send it to you.
out of interest, what size rear sway bars are you guys using?
My sway bar setup is Roy's old setup. It's quite unusual and I've had suspension people look at me wierd because of it haha. 27mm front! and 24mm rear. perhaps having very stiff front bar makes the car less oversteery and more neutral through long corners. That's where my car makes up a lot of time. Also is the most fun part of driving round a track :)
Russ - how are you find the G4 356's with he standard rears?
They're great. I love them. I would like to get a bias adjuster so I can make the rears work more but it's very settled at the moment.
My sway bar setup is Roy's old setup. It's quite unusual and I've had suspension people look at me wierd because of it haha. 27mm front! and 24mm rear. perhaps having very stiff front bar makes the car less oversteery and more neutral through long corners. .
Well this weekend was the first time I have driven it with a proper wheel alignment and the ARC swaybars and I am pretty confident in saying the car is slower with the ARC bars.
LOL, if you have any plans of binning yours then let me know. I also have the std Whiteline sizes, but I think I will just go custom again and copy the ones you are running
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
