That's awesome!
Bit of an update.
Got a new gearbox in today. Old one didn't have synchros in 3rd or 4th any more..
Cage is now painted. What a pain in the arse job!!! Don't want to do that again!
Another full day at the factory tomorrow for more prep for Winton next monday.
Had a big successful weekend.
Cage is now painted. Like I said. Don't wanna do that again!
Interior is back together.
Replacement gearbox
The car is back together and pretty much ready for Winton.
With help from my mate Johnny we had the alignment finished at 1am last night! We set up camber, caster and toe. I'm back working in Swan hill for the week so had to get as much done as possible before I left.
Before Winton I still need to finish wiring in my new AFR guage, change the oil, fix my camera mount to my new cage and I'm ready to go!
post-10715-0-78771700-1338896739_thumb.jpgpost-10715-0-15884400-1338896749_thumb.jpgpost-10715-0-50821600-1338896789_thumb.jpgpost-10715-0-56271900-1338896804_thumb.jpg
Next up is corner weighing! Will be interesting to see how much it weighs!
Replacement gearbox
Hah it's been ages since I've seen someone do the string alignment! I'd be curious to learn how you do it!
Yeah bris. At least it's only the battery!
Jack. The string alignment is basically an even rectangle around the car and measurements taken from there. Requires lots of patience. Camber and Caster is done with a made up tool. Courtesy of Femino (ACE Workshop) :)
Thanks Bris!
Massive day today at Winton. Had dramas all morning but I think I can put it down to me starting to look at the guages a lot more. Oil pressure dropped from like 6-8 bar to 2 bar sharply under brakes and picked up almost immediately after every time. This was very off putting and didn't seem right. I'm thinking that is always done it and I'm just taking more notice now that I'm stressing everything more.
In an attempt to try and stop the surge we put more oil in and it just blew into the catch can and put oil all over the engine bay. This might be just the icing on the cake coz I can't remember the last time I emptied the catch can... :whistling:
After this had settled down and I was trusting the setup more I was starting to lean on it and wow... the E85 pulls like a frieken train!!!!!!!!!!!!! It's unbelievable! 295's offered lots of grip even though the are quite 2nd hand. New coil overs were very nice and probably a little more settled than the old set. Not sure why but didn't get any turn in over steer like I did with the RE's.
Footage will come but the final time for today was 1:31.29 that's 2.4 secs faster than last year at SAU nats in October and now the fastest skyline around Winton on Semi's. Not sure how long it can stay like that for though haha. Thanks to all that helped out at the track or on the phone.
Disagree...If you do plumb it back to the sump then at least put a valve on it. You want to be able to observe how much blow by you are getting and if the oil is draining back then you dont have the opportunity to monitor. Myabe with a valve you can simply open the valve and drain it back at the end of a session. Also, catch cans are open to atmosphere generally and fill up with condensation and rubbish in a rarely driven track car that is only being turned over to move around factory or put on trailers etc.
Great stuff Russman.
So what rims and offset you have on the rear end of the car? Are you running GTR rear guards... have they been rolled?
Sorry I probably missed it earlier in the thread, thanks.
Thanks Bris!
Awsome work!
I had the same problem with my setup....Under hard braking....pressures dropped to about 20psi.... Although my motor didnt pop.. i am now going dry sump.
I ran a Tomei Oil pump with a Hi Octane Sump.... there was always enough oil in this but alot of workshops could not help with my problem. I was talking to a few people
and got some tips off the Gibsons GTR sump design with pickup points/baffling etc.... BUT one thing that did help was a Morroso accumulater (i actually have one spare now :P)
it stored ~1litre of oil under pressure and would expel when pressures dropped.... not really designed for this purpose of pressure drops under braking but helped my circumstances..... I was contemplating to do a external pickup but was too much mucking about on a 4WD that was already running. Also driving style helps... if you can try to settle the car more going into
these corners!!!... hope this helps
:cheers:
  • Like 1
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
