Unfortunately the new custom sump was modelled on an R33 and it didn't clear the swaybar enough when we put it in last week.
Because of this we missed out at PI on the weekend. I had brand new rubber on the thing and was ready to go but no such luck...
Turns out that the whiteline sway bar that is on my car was a prototype from years ago and they don't sell them anymore so pretty unique situation. The bend is very close to the sump so that's what has caused the issue. I think that a new 27mm sway bar with a better option that pulling the sump off again! Custom one being investigated now. Hope it makes the 21st!!
time for another update...
New 27mm swaybar has just arrived to solve the sump clearance issues. I currently have a loan 24mm until I get a chance to fit the 27mm. Might try both on the weekend if I can as a comparison.
Fulcrum suspension have sorted out the bar for me.
I've extended the wing end plates as the old ones were a little small and the bigger ones should hopefully stop a bit of the spill over the sides.
The splitter has come a long way. I'm still testing as it's all a bit new to me still. I'm really just copying what the fast guys do and following basic principles and advice I'm getting along the way.
I'll be logging the data at Philip Island this weekend to see if straight line speed is sacrificed and if corner speed is increased. As a bare minimum I'm expecting more downforce from just the splitter seperating the air and minimising air flow under the car.
If it all works the plan is to make the parts out of carbon fibre down the track. It's all trial and error at the moment.
loving the alloy canards. i made some about 3 years ago and was laughed at. been hesitant to make any new ones.
i seen in a build thread for an american R35 time attack car they made canards out of alloy. they were far easier and cheaper and did the same job.
are the uprights for your wing an off the shelf item?
Yeah the ally is pretty light except for the splitter. It's damn heavy. CF would be so much better
Nah they were made by superleggera carbon fibre in sydney. They're pretty hard core!
oh they look like a production type thing.
do you have any bracing under the boot lid? i may have missed it.
Hope you don't mind Russ. Most people probably know what happened already!
Russmans R32 GTST blasting around PI in it's last shakedown before WTAC!
For the full article check out Autocult -> CLICK HERE!
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
