So it's been a while since I've posted an update. That's because I've been so flat out! What a hectic month!
I'll go through the lead up first and then talk about WTAC and how massive the weekend was and how my mates/team helped me achieve a great result!
So PI as you may have read in Kory's write up didn't go to plan.
A faulty injector plug on cylinder 5 caused this...
The day after we had it pulled down and everything ready to go on Campbell's motor that he donated so I could get to WTAC.
We also noticed that the ASI ebay radiator wasn't handling the pressures of racing. Kinda a bit bent...
So we got a racepace spec radiator and so far it's great. temps have never been so low. It's crazy effective.
The lexan glass is now in.
Johnny and matt ripped into the doors and all up took out 15kg, that's just steel! Glass on top of that!
All this weight reduction got the car down to 1249kg with no driver and no fuel. Not bad for a full caged car!
So the mad engineers bent me up a Gurney flap for the rear wing.
Matt separating the fibreglass headlight from the mould. This by the way was tuesday night around 11pm. We left for WTAC on wednesday morning 5:30!
Front splitter painted last minute for WTAC
I think I'll leave it there for now. The WTAC story is a big one so I'll post that up at a later date.
That ASI radiator photo is exactly what flea-bay lovers need to see.
Good for a street car, not suitable for trackwork, reflected in the price.
I agree 90%
For most guys they are fine
But on a car like Russ'
Well the pictures speak 1000 words
Back on topic, how did you find the gurney flap Russ? Noticeable difference?
Love the build, though I'd be remaking the gurney lap if I were you. The height of the flap looks too large for the chord length of that wing. You'll be getting an inefficient level of drag associated with the extra down force the flap is creating. You should be looking at a gurney flap of around 5 -10mm in height.
Rad was fine for 1 year of track work. Got gradually worse. Seen them on other track cars so thought they'd hold up. No problems with cooling though, just construction. Looks like its deformed from high pressure. No head gasket issues, that's what we first thought haha.
Gurney flap and change of angle was very noticeable at turn 1 EC. The car felt way more stable and I think it may have had something to do with the final session being 1 sec quicker! The boot required re-packing after every session. By the end of saturday we had about 4-5 washers spacing it up! Need to do something more permanent now. Proper boot lid re-enforcement.
The gurney was actually mounted underneath the wing to begin with but spoke to an aero guy at WTAC and he recommended putting it above the wing so it sits higher as a result.
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
