NISSAN SKYLINE R33 GTR V SPEC 550KW
1995
550KW WITH DYNO SHEETS
BUILT MOTOR
800cc INJECTORS
SARD FUEL PUMP
OS GIEKEN GEAR SET
POWER FC
18X10 WORKS RACING WHEELS
-10 TURBOS
ADJUSTABLE BILSTEIN COIL OVERS
PIONEER STEREO
2X10" SUBS
AMPS
BREMBO BRAKES
HEAVY DUTY CLUTCH
HEAPS OF MODS
EXCELLENT CONDITION
VERY FAST STREET CAR
GENUINE ENQUIRIES ONLY - NO TIMEWASTERS
QLD REGISTRATION
$28000
NO SWAPS
PH <snip>
CLICK ON LINKS TO VIEW PHOTOS
https://www.sau.com.au/forums/topic/361212-nissan-skyline-r33-gtr-v-spec-550kw/
  • 3 weeks later...
My link
1995
BUILT MOTOR
800cc INJECTORS
SARD FUEL PUMP
OS GIEKEN GEAR SET
POWER FC
-10 TURBOS
PIONEER STEREO
2X10" SUBS
AMPS
BREMBO BRAKES
HEAVY DUTY CLUTCH
HEAPS OF MODS
EXCELLENT CONDITION
QLD REGISTRATION
$28000
NO SWAPS
PH <snip>
