Hi,
Well I've confirmed my worst today. My 33 GTR, which I've owned for 2 months, has low compression. I threw a gauge on it tonight and its down to 125psi on all 6 cyls. I dropped a bit of oil in the cyls and the compression came up to 170psi.
Unfortunately for me, I am meant to be super sprinting on the 1st May.
Does anyone know any workshops in Sydney that can pull an engine out for me this week? I know its short notice, I've called around a few places and everyones booked out till after easter.
If anyone can help out or know of anyone im more than happy to pay $$$$.
I guess it seems I trusted the wrong guy and bought the car untested on his word. I was told it has forged internals and it does have bigger cams. I just hope the bore isn't scored or anything else bad.
Does anyone know a good rebuild kit? Whats a good suggestion for bearings and head gasket?
Thanks heaps for any help you can give.
Craig
0424854025
https://www.sau.com.au/forums/topic/361245-rb26-rebuild-help/
hey mate give paul from red r racing a call, he probley wont pull the motor out but his work is the best i have seen his number is 0419259522. But he can be alittle hard to get ahold of sometimes
As ZEB said, it could be all fine.
Normally when a motor drops comp, not all of the cylinders drop the same amount. If they're all equal it sounds like a nice clean spec from when it was built.
Is it blowing blue smoke once warm?
What made you test it?
Hey guys, I pulled it down and was I lucky I did. it was 125psi across all 6 when the engine was hot. A couple of drops of oil down the plug holes and they came up to 172psi. It was also suffering from severe blow bye. When you reved it the oil pressure would rise above the full pressure 8 kg/cm or what ever the reading is.
When I pulled the engine down I found a few surprises.
1. The thrust bearing was torn to shreds. The crank was suffering anodizing due to it.
2. The conrods had a really dodgy polishing job. They were standard rb26 rods, but one had started to crack due to where the buffing pad had cut into the rod.
3. Several of the conrod bearings showed severe flat spotting in the 6 o'clock position indicating detonation or pinging.
4. The rings were worn bad and the hissing noise past the pistons were crazy.
So now I've done the following:
1. Ground the crank and bought new acl race bearings all way around.
2. New Nitto h beam rods
3. New Nitto oil pump
4. Ground out the exhaust manifold where there was massive restrictions.
5. Metalcraft 9 liter sump
6. Mines cam baffles
7. UAS oil air seperator
8. 3 liter cusco catch can
9. 1.2mm and block off restrictors
10. Nitto drag series 1.2mm head gasket and full engine gasket kit
All I need to finish the rebuild is
1. Just jap silicon hide kit.
2. Tomei rings to suit my tomei cooling ring pistons.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
