  • Replies 376
Posted Images
There are issues at their end with DNS etc that can cause a few problems and increase your ping. Mine hovers around 300 all the time.
Yep play it the same way as it is bassically the same tank but just not as good but it most of the time you are the top Tank :D
I have played just 6 games for 5 wins, the loss and first game I had 7 kills but we were capped. Lowe makes more money and more easily with it's much better gun.
yeah the lowe does and so does the T34 but i prefer the play style of a medium so i play it more than the others
Finally received the Ace Tanker badge on the Type 59 after 16 battles.
This kent tells me he 'saved' me from a KV-5 after repeatedly shooting my VK4502A in ass with his Grille instead of shooting either the KV-5 or the E8 that was actually doing damage to me not the KV-5. Should have just TK'd the POS.
42%ers should be executed in the streets, just saying.
Just "downgraded" from my T25 AT to a T28 TD... useless slow paper weight.
I want my T25 AT back!
Also thinking off selling off that 1/2 useless "pretending to be a med but fails" IS-8 to fund for IS-7.
Yeah after I unlocked the T28 I sold the T25 AT but didn't buy the T28, only way I would play it is if I free XP'd the parts and tier 10 gun.
I think I'll go down the second line to the T30 instead.
Getting pretty close to the T110.
IS-8 was sold after one game, I see no point keeping an inferior tank. Barely even played the IS-4. plus I needed the credits for the Object 704 and it's sweet sweet BL-10.
I used free xp to get the final 120 gun for the T28 & my final verdict is still the same: "useless slow heavy paper weight rubbish" & "I wasted my gold on this POS?!"
Can't rely on the so called '254mm' frontal armor at all since the useless thing has too many weak spots at the front & get pentrated frequently even by a Tiger H & its too dam slow so if you are spotted you pretty much f**ked neither way.
Played 10 games with it & already want to threw its useless US arse to the bin (like that Panther I had for 10 games, sold shortly after in the same day). Only thing stopping me doing it is that I already wasted gold on it...
EDIT: screw the gold, just sold its arse regardless, buying back my T25 AT.
Edited by Mayuri Krab
The Panther is a decent tank.
The T28 is not.
Picked up the T110 then my premium ran out :( Training up the T110 crew in the T34. Shame the T34 is such a turd of a tank. Doesn't suit my play style at all and has all the same 'this is not a heavy it's a crap TD' issues the T30 had/has.
Lowe shits on it from a great height in all but alpha damage really.
I love it when people that are dead tell me what not to do, I do it and kill everyone, like a boss. Type 59 player was telling me to rush back down the hill on campinovka, drove up and killed a M103, IS-8 and IS-3. Love the 704, averaging over 3k damage a game iirc.
Yeah that was a pub game, I was mid table.
Since getting the WoT assistant it turns out arty is dragging me down, I have something like a 40% overall win rate in arty with everything else fairly high. Apparently anything 55% win rate and above is in the top handful % of players.
Playing the Russian little arty anyway, not great so far.
I still LOVE the 704, wish I had gone the Russian TD line from the start and just played the shit out of that tank, it's epic.
I'm having a good run with my Grille, that thing seem to be firing homing missiles...
I aimed at tanks while the aim circle wasn't even fully closed yet it still hits them most of the time. This compared to that M37 always seem to miss even when I have the aim circle pretty much on top of the target.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
