  • Replies 376
Posted Images
HawkEx (8:20:09 AM) You f**king premium twat, play without your premium shit for JUST 1 DAY n then you'll know how BIG moron you are.
HawkEx (8:20:40 AM) Still, no need to say to a premium retard who don't have brain to understand.. so f**ker play with our gold shells i nthat tank n show urself flamin mongrel
Tanks are srs bsns.
Especially for 47%ers
  • 1 month later...
Your kidding, mongrels
Only arty interests me out of the while time I played and I was in the closed beta for 6 months I've only played about 5% tank the rest arty
Then I have no interest in having you back :P
Arty is an irritant and ruiner of game queues.
Hahaha :'( ... Good arty you mean
No, all arty, it unbalances the match queues especially on SEA.
Also 8.3 is tonight, no clue why they do these updates on SEA at prime time.
Edited by DivHunter
Finally I get to drive the tanks endorsed by Chairman Mao... :yes:
Does anyone on SEA had a ping increase lately?
used to be 70-80ms, then went to 400+ms & finally have settled down to ~230-270ms these following days.
I want my old pings back!
Edited by Mayuri Krab
It's not just WoT, it's everything to Singapore etc because the SEA-ME-WE (hehe) cables are down so everything is re-reouted. Internode re-routes through Japan.
The Japanese tank tree is pretty funny.
FYI the top 100 games in each of the 17 Chinese tanks will recieve gold on Feb 10th counting games from when they came out until then. You just play, no screen shots or anything.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
