hey doglet i'm in bris and can only get them here in bris, sorry dude
hey siu where bouts u live in brisbane and meet up sumwhere and compare our cars cos i got similar mods to urs and just got a dyno run recently as well. and yeah we'll sort something out wen yuo need sumfin. cya round
any1 else needing parts, please be aware that i can get brand new genuine nissan parts (not second hand) and should the part u are after is coming from japan it is a 1.5-2 week wait and also requires a 20% deposit. if the part needs to come from another warehouse/nissan spare parts joint in australia then 2-3days with 20% deposit, if coming froma brisbane warehouse then within a couple hours(24hrsmax) and a 20%deposit. so please take this info into account when considering thanks
redline: it would depend on parts like 6 platinum plugs for 32 my friend was quoted 110-120 i got it for him for bout 60-70 dollars. usually the more expensive the part the higher the saving
fatgtsr: not confident or prepared to send it interstate due to possible problems like wrong part/damage etc.(u never know) and it will be a hassle sending it back to bris for refund/replacement esp. if coming from japan. sorry to disappoint
I got a nissan key blank for my GTR - just wondering if its possible to check nissan databases or whatever to find the lock code (ie X----) so I can get a locksmith to cut the key for me???
if not ill just have to take off the door trim & find the door lock & check that out. Thanks
Guest
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
