i have searched but im not quite getting the info im needing. i want to know where i can T my boost guage off of. where the standard rb25det boost guage comes off is now used as a map sensor for the microtech. where else can i T my boost guage from.
https://www.sau.com.au/forums/topic/361327-boost-guage/
it shouldnt really matter if you tee into your map sensor line. Its not Venting the pressure, it will have a sealed unit with some sort of spring arangement or something more technical. So more boost will push the spring further and create less resistance something like that anyway
any boost/vacuum line that comes off the plenum is fine, as long as your happy to use it. I have the MAP Sensor for my PFC boost control kit and boost gauge MAP sensor tee'd from the one line
https://www.sau.com.au/forums/topic/361327-boost-guage/#findComment-5767490
There is a vacun hose coming out of the intake manifold it's very close to where the clutch fluid goes I'll take a pic for you in and hour when I finish work if you haven't figured it out by then
+ 1 where I did mine, no problems and it means you get to use a shorter length of Vacuum hose.
https://www.sau.com.au/forums/topic/361327-boost-guage/#findComment-5767659
yeah thats the one used for the map sensor
https://www.sau.com.au/forums/topic/361327-boost-guage/#findComment-5767689
