lads,
got a set of pearl white genuine Dayz sideskirts for sale to suit S2 Stagea.
these are in great condition, from memory, no scratches whatsoever. All clips in place. There are 4 pieces in total. They are currently living under my parents house gathering dust so no actualy photos, but illustrative photos below.
Looking for $350 ONO
pick up in Melb or door to door courier can be arranged by buyer.
PM me if interested.
jay1.jpg?w=450&h=272
https://www.sau.com.au/forums/topic/361330-s2-dayz-side-skirts/
sorry mate, completely forgot i had them. was under the house on the weekend getting my airbox and saw them propped up.
welcome to put yours up for sale and buy mine if you need pearl white specifically?
bump.
would also consider selling my Nismo side skirts in pearl white if anyone interested.
Have been prepared and fitted to the car so no hassles with fitting them straight up. Very very rare item, and only considering selling because i want to lower my car more and i probably won't get into my apartment complex without damaging them. Pickup only for these, as they're fibreglass and i'd be worried about them breaking in transit.....
$450 ONO
Edited by SMOKEYC34
bump.
$450 ONO
Damn, I'm on the wrong side of the strait! If I could work out how to safely get them to Tassie I'd be very interested!
i'm happy to work with you on finding a safe solution - i mean, they obviously got to here somehow as they didn't come with the car!
i am just hesitant because they are such a rare and expensive item. the plastic dayz ones would stand up to a beating, but the fiberglass ones might be a bit less forgiving if they were handled roughly.
Cool. I might do some measuring tonight to work out roughly how long they are and then see what some of the freight companies think.
no dramas. i can drop them at a courier depot in melbourne metro if that helps. plcaes like pack n send would be able to do something for you perhaps??
it will be a case of either or. so if they dayz skirts sell first, i keep the nismo's and vice versa......can't haev my gal running round skirtless!!
No worries, I'll contact pack n send tomorrow and see what they say, then I'll let you know
Can you please measure the height of them for me?
yes mate.
will get you an exact measurement tonight but generously estimate 40cm high just behind the front wheel.
they are about 10cm deep also.
brilliant, that's gives ms something to get a quote with
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
