hey all, lately been having 2 problems with my car, most annoying one is missfiring randomly, just random times it will missfire cruising or standstill, but to remove of the misfiring i just slam the foot to the floor and build up boost and it will go away..... any ideas??? just changed to new sparkies, and had the splitfires in for about 5000km.
this really really pisses me off. car sounds all nice and roaring and then all of a sudden its a god damn tractor!
2nd problem is, if i come around a corner or i do burnouts the car will smoke up to a certain point and them it just cuts out, never used to do that. i hit about 4krpm and then even with foot to the floor the engine will just cut off, completely and just go into idle mode. never die, or stall, but just stay at the 700-1500rpm even with foot to the floor.
i dont have a traction control in the car, and even on full tank it will do this, i first thought it was a fuel related problem not getting petrol when swinging into corners.
any help would be appreciated.
https://www.sau.com.au/forums/topic/361335-rb25det-neo-problem/
splitfires were brand new, missfiring fixed, one joint on the plug loom was loose so didnt get a proper connection, fixed that and now seems fine *fingers crossed*, other problem still exists.
saving up for a Power FC after i get my FMIC and front plenum sorted out.
that top plenum is the biggest btch
problem will not be r&r, so ignore all posts about that. if it is only when cornering it is going to be an electrical issue where something is losing contact while cornering. i would hazzard a guess and say the afm. try checking the fault codes.
