It involves doing a google search to start off.... then you may find some info that is already out there such as this... http://www.datfusion.com/forums/index.php?showtopic=3&mode=threaded
or even another thread just like this where someone has already been flamed and provided with links... http://www.nissansilvia.com/forums/index.php?showtopic=467906
:domokun:
https://www.sau.com.au/forums/topic/361344-sr20de-na/#findComment-5767759
I have done this conversion a few times and recommend the following:
S14/15 OEM exhaust manifold
S14/15 OEM turbo + all elbows and intake snorkel
3" off the shelf TBE to suit your model
Brass T-piece for oil pressure switch from Pirtek
1M oil line to meet T and turbo from Pirtek
2 x banjo-bolt barbs for 5/8 water hose to suit turbo
3M 5/8 HIGH TEMP water hose and 4x hose clamps from turbo to throttle body
1 x turbo drain pipe and sump drilled in OEM blanked position to suit + hi temp oil resistant hose (roughly 40cm)
off the shelf FMIC kit to suit your model
any SR20DET injectors (from S13-S15) even RB25DET ones will work
Fuel pump
ECU remap
You will not need to change the AFM as the factory AFM is equal in capability to the DET AFM. You cannot use the DET ecu as it is a different harness and uses coilpacks etc (yet I have also done this conversion too)
Expect an easy 180rwkw that will be faster than your average 'bolt-on' SR20DET setup.
The above in an S13 has net me 0-100 in under 5s and 0-200 in under 13s, the torque from the added compression is valuable to say the least.
Alternatively you could spend $3500 on a halfcut then put a TBE, FMIC and make an average 160kw (unless you get something T28 powered or put one on).
https://www.sau.com.au/forums/topic/361344-sr20de-na/#findComment-5768642
