7Th May - Gold Coast Gtr Club Meet/cruise
OK
Am finally there again, this Saturday night!!!!
I hope to see as many GTR's as possible and of course other car enthusiasts!
Hopefully NO rain!
Look forward to seeing you guys again!
Kymbo
  • Replies 157
Posted Images
hay where the meeting point and what time cus ill be coming out as long as i have a address to put in the GPS
Hey mate. I believe the best address would be Corner of Gold Coast hwy and Admiralty Dr Surfers Paradise. we are opposite that in where the indy pit lanes are. If you go on where is you will see the serice road that runs along Gold Coast Hwy which is opposite the intersection i mentioned before. There is concrete walls there so it's abit hard to see us behind them, so just turn in at the lights and you will see us there. if you have any issues you can call me on 0488 585 225. il be there. Meet up is at 9. But usually we all try get there between 8:30 and 9:00. Hope to see you there.
Here is the map. well at least im 99.9 % sure thats where it is. Kym can confirm it.
http://www.whereis.c...=65E453BC018A87
- Ivan
Edited by SNiPeR33
Hey mate looks like we just have to wait till next months meet :(
I got one of the guys making me carbon fibre end plates for GTR wing on my R33 cant wait to get them. And i might get him to make me the blade too :)
  • 3 weeks later...
How many people do you think will be showing up on Saturday night?
Im not sure mate. hopefully we get all the regulars. will see by saturday if other people that are coming could hopefully let us know on here. But either way il be there.
I have heard from a mate that possibly the gold coast 600 things are still in pit lane which means we wont be able to get in. If anyone knows if this is true or anyone planning on going tonight please let us know on here otherwise no-one will show up. so if no-one says they are going il take it as a no go too.
Thanks
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
