R34 Tiptronic gear selector set up in pretty gd condition $60
R34 White Bonnet in Great Condition $300 o.n.o (PICK UP ONLY! UNLESS BUYER ORGANISES COURIER)
R34 Bonnet catch for Gtt or Gtr $50
R34 auto tailshaft $40
R33 Manual Shifter $50
R34 Auto non turbo ECU $50
R32 Gtr Brakes, 4 pot front and 2 pot rear. Comes with crossdrilled rotors too! $500
Offers are more than welcome as i need the stuff gone! But no low ballers please!
there's my mib anyway: 0432647023
pls msg before calling during bus hours.
Cheers
Herbie
R34 Tiptronic gear selector set up in pretty gd condition $60 $50
R32 Gtr Brakes, 4 pot front and 2 pot rear. Comes with crossdrilled rotors too! $500 $400
Cheers
Herbie
R34 White Bonnet in Great Condition $300 o.n.o $280
R32 Gtr Brakes, 4 pot front and 2 pot rear. Comes with crossdrilled rotors too! $500 $400 $350
All prices do NOT include delivery. Happy to organise delivery at buyer's expense!
there's my mob anyway: 0432647023
Cheers
Herbie
Edited by GTXR34
R34 Tiptronic gear selector set up in pretty gd condition $60 $50 $40
R34 White Bonnet in Great Condition $300 o.n.o $280 SOLD
R33 Manual Gear Shifter $50
Cheers
Herbie
Bump
will seperate brakes too.. i.e calipers and rotors and even front and rear calipers if find buyers for both.. $200 for front calipers and $150 for rear calipers.. $50 for rotors (there's not too much meat left on them)
Cheers
Herbie
R34 GTT Standard raditor with 1.1bar cap, only a couple of fins bent but nothing that will make any difference at all ------------ $50
R34 standard dump pipe and front pipe with heat shield on front pipe ---------------- $60
Cheers
Herbie
Not sure wat car they fit 100% in regards to the lines n thickness but will definetely fit on the hub.. All the rotors have a bit of a lip but still usable..
Cheers
Herbie
R34 Tiptronic gear selector set up in pretty gd condition $60 $50 $40 SOLD
R32 Gtr Brakes, 4 pot front and 2 pot rear. Comes with crossdrilled rotors too! $500 $400 $350 $325
Cheers
Herbie
R32 Gtr Brakes, 4 pot front and 2 pot rear. Comes with crossdrilled rotors too! $500 $400 $350 $325 SOLD
R34 standard dump pipe and front pipe with heat shield on front pipe ---------------- $60 $50
Cheers
Herbie
  • 3 weeks later...
  • 1 month later...
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
