S A U N S W - Texi, Skids On Sunday, 12Th June 2011
Hey guys, how can I set up a temporary fire extinguisher mount? I really wanna enter this but stuck on the extinguisher side of things and dunno where to mount it.
Cheers in advance for any help.
Do a search, Cassbo did a small tutorial on where and how to mount a fire extinguisher in your car. Personally, I've mounted mine using one of the brackets for the cushion of the back seat, and seeing as it doesn't interfere with footspace, I've just left it there. (Granted, I'm driving a Stagea, so it might be different to your own applications.)
  • Replies 244
Found it!
http://www.skylinesaustralia.com/forums/topic/198337-r33-fire-extinguisher-instal/page__fromsearch__1
Payment sent. ill be faxing the form off tomorrow at work
Cant wait for this, its been so long since my last event!
paid today, just have to plug fax machine in so i can send through form unless you can use the one i sent through last time
Mate cause of the date printed it's got to be the current form
R34 for this one?
R34 for this one?
yeah i hope so, it's seems to have a vac leak and is hunting a bit.
form sent, finally got off my arse and run the phone line to the new office
Ok small update ppl.. Im currently away from home for the week so there will only be 1 update on tuesday so dont freak out about not showing up for a few days..
atm ill allow number reserving BUT if it gets out of hand OR if there are a few spots left people will be moved up the list to make my life easier.. The end of the day it makes no real difference and you dont need big numbers on ur door or anything like that like if you were going to do a hillclimb..
Lol yeah please don't go to Tweed
I'll put up a map when I'm on a normal computer, not iPhone. But if you go to the TAFE website, get the address for Quakers Hill TAFE and put that into google maps. When you arrive there you go in the entrance from the main road then follow that road and after a few roundabouts you will see us on the right hand side. Follow that road to the end, turn right and you will be staring at the carpark where everyone will be waiting :)
Its nice having backup cars isn't it haha
Guest
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
