Hey all Im over drift and want to empty my shed so here is a list of all the goodies you can get your hands on.
I am located in Whyalla SA and will post almost anything anywhere in AUS
· Garret GT 30/40R .63 exhaust housing T3 flange $1200
· High flow RB25det turbo (GT2871R core) $800
· Microtech LT12s, RB25det plug & play adapter, hand controller, X6 igniter & 6 bosch coils $1500
· New Kazz 2 way lsd still in the box for S14, R32, R33 $800
· Used 2 way lsd in R33 diff housing $600
· R33 skyline no motor or gearbox rolling shell $1500
· RB25det race motor, built by lewis engins, race prepped block, blueprinted and balanced internals, Tomei oil pump, New RB26 crank, Scat forged rods, JE forged pistons, gapless rings, race ported head, full reco head, Tomei valve springs, hi energy sump, adjustable camgear, Extreeme light weight flywheel & 1600 kg puck clutch. This engine has been buit to put out over 350rwkw all day $6000
· RB25det gearbox $700
· R33 manual conversion, pedal box, clutch master & slave cylinders and lines, tail shaft, gearbox crossmember, gear boot surround $500
· R33 pumped metal front gards all metal big flare suit drift car $200
· Surge tank, Bosch 044 pump, bracket & speed flow fittings $300
· New 650cc top feed injectors, fuel rail, speedflow suit RB25det $550
· Haltech interceptor platinum suit any car $500
· Whiteline swaybars, pillow ball front linkages $350
· R33 3" Cat back exhaust with cannon $200
· R31 3" custom cat back exhaust with cannon $200
· Heaps of other skyline and performance parts, just txt or pm me with what your after
more pics coming soon or ask for specific items
Open to all serious offers
Shaun 0412 445 360
What brand is the used lsd and will you seperate the pillow ball mounts off the swaybars?
May consider parting the pillow balls from sway bars, what are you offering?
As for the diff it has no makings on it, then again nither does my new Kazz 2way :blink:
Hi there the 25 box is in good working condition, but yes has very worn synchros so if you dont drive it right it will grind the gear a lil into 4th mainly.
Yes I can get a quote for you to ship it to nsw at you expense.
My honest recomendation is that you put a new set of synchros through it and it will be good as gold
And yes it's definately a turbo box it's from my gtst
what is the rail that comes with injectors? pics?
Il get a pic of the rail today
Its just one of those ebay purple hks imitations comes with all fittings and injector reducers, speed flow fittings -8.
It will fit a forward facing manifold, I tried fitting it too a stock manifold and it didnt fit.
what mm are the swaybars? and are they adjustable?
also keen on the kaaz 2 way, do you have receipts for it? diff looks good but box looks ancient lol
also keen on any other r33 suspension/drift parts you may have.
pm me champ.
cheers
Adrian 0435 430 440
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
