All,
Iv bought the V Spec2, R34 Pedal set and I am having trouble installing the clutch and brake pedals. Given the originals are rubber they are easily "rolled" onto the pedal assembly however given the new pedals are aluminium they are not as easy to install. Any Tips?
Secondly,
Is anyone aware of the Part No. required for the bushes required to fit V Spec 2 R34 Pedals onto V Spec Model?
I installed mine a week or 2 ago, it was absolutely pain in the ass to install the brake and clutch pedals.
It took me about an hour to get them both fitted.... lol
At the end, I just used a heat gun to heat up the rubber on the back, to make it a bit softer, then quickly try and stretch it around the pedals. Might take a few goes but it will work.
As for the bushes, I have a bush from the accelerator pedal that I don't need for my GTT.
Ha Ha! Thought I might of been doing something wrong! Lost skin on my finger tips trying to get these on! I'll try the heat gun!
Mate if thats the only part required can you please PM me a price incl postage to 4122.
Ta Charles
Haha yeah, its a f***ing pain!
But what I also realise is that you can actually bend the pedals if you aren't careful, the aluminium is bendable.
I also sent you a PM :)
  • 2 years later...
Is the Accelerator pedal hard to install? it doesn't look hard just from looking at the pedal, but looks can be deceiving, what would i need to take off in order to install the accelerator pedal?
^ If you have a GTT, you need to trim off some of the pedal (after you remove the old plastic cover of course). I took about 10mm off the top left edge and files it down, painted it and then the GTR pedal cover went on nicely. There must be a difference between BNR and ER 34 accell pedal's.
hmmm I cant remember specifically installing the footrest but I do know that the accellerator was the hardest part for me, thats in a r33gtst...
I would of thought 34gtr would be easy considering its made for that car...
It's a poofter of a job doing the clutch and brake pedals...
I sweated and huffed and puffed and cursed and cried a little inside before mine were on.
My fingers felt like I'd smacked them with a hammer for 5 minutes straight after it.
A good looking simple upgrade though!
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
