Best yes, to go to a person who knows the idiosyncracies of Skylines.
Around Sydney/N.Sydney?
1) Tune House at Marrickville
2) Powerplay Imports at Drummoyne
3) Envy Imports at Brookvale
I'm not sure who services the Skylines from Northshore Prestige
If it were me, I'd go to Tune House first.
If you don't mind travelling,
4) Unigroup Engineering at Girraween
5) Dart Engineering at Punchbowl
6) Croydon Racing Development
Best Price and Communication out of the above?
* Unigroup
* Tune House
* Dart
https://www.sau.com.au/forums/topic/361417-car-servicing/#findComment-5768963
If by service you mean a oil change, filter,plugs, radiator flush,you should do it yourself.
Saves a lot of money so you can buy the best parts.
Hell, you could do gearbox and the diff oils as well and still be way infront.
Mark
https://www.sau.com.au/forums/topic/361417-car-servicing/#findComment-5769582
The average of my alto has dropped to 13 kmpl...till the last month it was giving arnd 16-17 with ac on...As i am going to give the car for servicing sometime nextweek, i would like to have inputs from u all as to what things i need to check with or get replaced in order to enhance the average. bmw tail lights
Edited by Mod. Fixed the link :)
Edited by NISMO
https://www.sau.com.au/forums/topic/361417-car-servicing/#findComment-5770108
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
