I'd just like to thank all the ppl that came and helped me monday night to get my daily laser back on the road to get myself home.
it just so happened to be out front of MSD00F's house :D (among everyone else that lives there too!)
Thanks again guys, now i have to make a Donation ;)
https://www.sau.com.au/forums/topic/361419-best-place-to-breakdown/
no worries! good thing you did break down RIGHT OUTSIDE MY HOUSE! lol... 2 mechanics and a housefull of spare parts and tools to get you back on the rd for any situation haha... AND sau ppl that you know! :P
awesome timing too as we were all calling friends over at the time :P
well for future reference folks, break down outside my house! :P
Tim, did you end up getting a new battery?
Who were the two mechanics? It sure as hell wouldn't be Jay and Steve :P
i got home..
then in the morning the car wouldnt start with out a jump, so i put it in for a service at a friends local, bought myself a new battery got belts replaced and now she is running well again.
it just needed some TLC Galois, i picked it up cheap so i wouldnt need to drive the skyline daily to nortyh ryde and back.
as long as someone is there to keep the beer flowing for the spectators... errr,,,, mechanics, i can't think think of a better place to break down!
perhaps if there were also tits at the break down location... now i'm just being silly.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
