Insert mediaMedia URLInsert email addressEmail AddressLink textInsert imageImage URLInsert linkURLLink text
moving house in the next 2 months so cleaning up all my stuff i have lying around from wrecking cars over the years
if there is something you need that's not listed pm me i might have it (NO INTERIOR PARTS)
r34 boot lid with gtt wing $180
r34 2dr tail lights $100
r34 clutch fan $50
r34 neo cover $30
r34 stock intercooler core $70
r34 alternator $50
r34 air con compressor $50
r34 cross over pipe with b.o.v $50
r34 rear bar (no reverse lights) $80
r34 front guards in primer $130 each
r34 manual dash cluster $100
r34 2dr passenger door $150
r34 2dr drivers door $150
r34 gtt bonnet $200
r34 rear quarter panels $100 pair
r33 s1 type m front bar $100
r33 s1 front reo $50
r33 s2 boot lid with wing $60
r33 clutch fan $50
r33 side mount core $30
r33 alternator $50
r33 turbo elbow $30
r33 nismo clear side indicators $30
located in western suburbs s.a
loading.gifcloselabel.gifLoading...
https://www.sau.com.au/forums/topic/361421-rr34-and-33-standared-parts/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
