Guys,
Recently after swapping my turbos to -9, i can hear this soft whistle sound when i take off mostly on 1st and 2nd gear....
is this something normal or should i get it checked???
It sounds like one of the trucks that have whistle sound, but this is not as bad as that....
any ideas guys?
https://www.sau.com.au/forums/topic/361423-turbo-issue/
Sounds like a boost/vacuum leak of some sort.
I'm assuming you've checked everything is tight and not leaking? Silicone Joins/Intercooler Piping/Intakes/Bolt on the turbo housings...
Matt
Yeah, the turbo's been professionally fixed....
It was fine before the swap, just happened after the swap...
https://www.sau.com.au/forums/topic/361423-turbo-issue/#findComment-5768663
I'd take a stab it'll just be the turbos themselves mate.
you've gone to turbos with bigger wheels, and they are steel not ceramic rear.
They do "whistle" a bit.
If i didnt have the aids at the moment i'd tell you to come around and i'd tell you in 30 seconds lol. But im stuck in bed :(
https://www.sau.com.au/forums/topic/361423-turbo-issue/#findComment-5768826
cool thanks mate....aids?? :O
https://www.sau.com.au/forums/topic/361423-turbo-issue/#findComment-5770383
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
