Up for sale is my project car i have been working on for 3 years, standard Blue in colour i have listed below current parts / modifications etc, interested in stripping for the right price whole car goes for $5,500
RB 25 DET done 55,000 (out of a r34) wiring loom and ECU
Manual gear box
Excedy 3 plate button clutch (on or off)
lowered suspension
new front mount
Z32 AFM
stainless steel cat back exhaust
series 2 dash and cluster
retrimed Blue and white interiour (excluding Driver seat)
* Roof
* Rear Seats
* Passanger Seat
* Door Trims
Fluted Bonnet
After Market Fuel Pump
Pod Filter
=Much more that has slipped my mind=
I will update with some pictures soon but if anyone is keen please e-mail me
[email protected]
0405 124 906
Edited by Ranga!!
https://www.sau.com.au/forums/topic/361430-r33-unfinished-project/
  • 4 weeks later...
Guys
i will get some pictures up tonight, also please note that i intend to sell this as a running car- unfinished project, this of course is negotiable and if you want to make any offers please call me, it is a complete car at the moment just needs a paint job and ready for rego.
0405 124 906
Trevor
Edited by Ranga!!
Please keep in mind it is ready for primer and I intend to paint within two weeks, once painted I will be very reluctant to negotiate price, all dints scratched etc have been repaired.
post-76886-0-97376700-1305672740_thumb.jpgpost-76886-0-49039200-1305673010_thumb.jpgpost-76886-0-66745500-1305673054_thumb.jpgpost-76886-0-61111400-1305673109_thumb.jpgpost-76886-0-39261300-1305673130_thumb.jpgpost-76886-0-62120700-1305673161_thumb.jpg
Interested in the radiator, suspension(if after market) and the A pillar with gauges. Inbox me if you're going to separate. Need a thicker core radiator to install when my belt goes on and that looks thicker than stock. Do you know brand or specs?
Also interesting to see the passenger side air bag in a series 1.1.5 didn't have the air bag, did it?
Edited by SargeRX8
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
