USB 3.0 uses a different chip on the board, IIRC. it's possible that routing through that board is making the PS3 not understand.
It's like a WD external I got recently, the 2.5" 1Tb: the board on that goes direct to USB 3.0, so it has something called WD SES that needs to be installed, basically a SCSI interface driver of some sort. Maybe the PS3 doesn't like that at all..?
You could be right. It's a Samsung and it likes to launch Kies every time I hook it in. I don't allow it to but yeah.
So by using a USB 2.0 cable, I'm guessing it bypasses the USB 3.0 functionality... Seeing as the 2.0 cable doesn't plug into the extended section of the port.
getting back to the YLOD fixes, this happened to me last year with my original 60gb phat console and it sat around for 4-5 months before i learned how to fix it.
the re-flow method worked for me but only lasted another 2 weeks, then the 2nd time i fixed it it lasted 2-3 months and i had cranked the heat gun up way hotter that time, the mobo was actually bending under it's own weight but straightened back out as it cooled.
from memory it only lasted a couple days the 3rd time and then didnt work at all after the 4th so i cut my losses there and bought a new slim.
what really shits me is how sony have made it absolutely 100% impossible to back up your data manually by taking the hard drive out to get the data off. the ONLY way to read your save games etc is using the EXACT console that that the hard drive was formatted with.
any other PS3 other will not read your hdd.
you cannot read it using a PC.
the only real way to guarantee your stuff gets backed up is to:
A: regularly back up all your saves to a usb flash drive (my favourite option) or external hdd.
B: get a PSN Plus membership, which lets you back up your saves online so sony holds all your data for you.
thats about the only potentially valuable feature of plus if you ask me. other than that its just a few free themes/avatars (lame) and waste of time really small discounts (5-10%) off SOME dlc items/games. for what it costs.. total waste of money IMO
You seriosuly can't just move the HDD to another PS3? That's harsh and I was annoyed when I found out my brother's original version xbox wouldn't read the USB stick I use on mine. You can just swap the HDDs though.
Yeah I agree. The backup process in the ps3 is of the ghey.
If anything, allow it to be swapped into another ps3 and just have some sort of password security rather than being forced to back up into portable storage and having to format the hdd...
That's the only way to back up to another medium.
A way to use the network is if you have two ps3's and transfer the data from one to the other. This then deletes everything off the original ps3. And it's also the only method where EVERYTHING copies over.
I installed everything into my new ps3 from the back up and all of my demos and games stored on it are no longer there. Videos n music remains though.
Yeah thought as much. I suppose it would take away from the ps plus feature of saves being backed up automatically if you could do similar for free.
Demos and games aren't really an issue as you can just re download them, albeit a waste Internet usage. But it would suck to loose all my saves.
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
