Was out on a brief drive this afternoon to log some data via my consult cable using ecu-talk. I do this every week or so in different weather conditions to check for problems.
I had driven for about 40 minutes when I pulled into a service station to refuel. A look at the data at this point (while the turbo timer kicked in) showed me everything was fine, with temps not getting above 85 deg C.
After refueling and paying the petrol man (a total of about 5 minutes), I started the car again and quickly noticed the ecu-talk Water Temp gauge flashing, indicating the temp had exceeded the set value of I think 95 deg C. Very interesting I thought because as I was looking at the ecu-talk gauge, it was indicating 92 degrees but dropping very quickly i.e. within seconds.
So I drove down the road to my house and got all the data in to Excel. This is what I discovered:
At the point of turning off the car, temp was 85 deg C
~5 mins later upon restarting the car, the temp was indicated as102
A fraction of a second later it was 101
A fraction of a second later it was 100
and so on until 5 to 10 seconds later it was low 90s
A minute later is 90
As I started moving it dropped below 90 and once up to 70kph it dropped very quickly to below 80.
Can anyone explain this? Any guidance appreciated. Cheers
The engine block & internals are always hotter than the coolant, there will be a temperature differential. With the engine off, the block will slowly heat up the coolant about 5-15c but will cool off with time.
Thanks moodles. Do I need to be concerned that the coolant is going 100+ for a while when the car is off??
Do you notice any coolant boiling when it hits over 100 deg C?
Its usually noticeable in the overflow bottle or a bubbling noise around the coolant hoses, mine did that due to a worn out rad cap not holding proper pressure.
If it is not boiling then I wouldn't be too worried.
nothing to worry about since the car wasn't running. the coolant keeps flowing to a certain extent when the car is off so it keeps drawing heat out of the engine but not as fast and the coolant isn't being cooled much by the radiator. some cars with thermo fans controlled by the ecu don't have the fan come on until up around 100 degrees.
the fact that the temp started dropping as soon as the car started running then you know that your cooling system is working.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
