Hey guys as the title states i'm chasing a:
R34 SMIC in good condition
aftermarket RB25 3' dump/front pipe
small size electronic oil pressure gauge with fittings etc
also possibly looking for an aftermarket RB25 low mount manifold
I would prefer local pickup except for oil pressure gauge if you are happy to post. I'm located on the gold coast but happy to travel to brissy/sunshine coast for good stuff....
Cheers guys, let me know what you got... preferably with pictures
PM me, or text 0411967856
Steve
