I have been having an intermittent problem with the starter motor not cranking over but lately it is happening more often.
Symptom - i will turn the key, can hear the clunking of the starter but won't crank. Occasionally it will start no problem though... when it decides it will.
So far things i have;
Checked & cleaned starter connections
Checked & cleaned earth points
Installed new battery
Without fail i have been able to get it to start by rolling the car a small amount - letting the clutch out to stop then turning the key. Also if i jump start it that will always get it cranking over, possibly also if i have immediately taken it off the battery charger (though haven't tried this enough)
I am wondering if i should bother getting another starter or i should install a relay on the starter motor circuit. I have done a search and it seems the relay is a pretty common fix, i am a little hesitant as it does add another albeit small point of failure... It is an R32 also, so i suppose all of the wiring etc may be a little tired?
Would like to know what others have done
https://www.sau.com.au/forums/topic/361500-rb26-starter-problem/
Sorry should of specified also - it just does one clunk per 1 key turn. Gotta keep flicking key on and off to hear the clunk otherwise usually don't really hear it... just fuel pump working and dash lights on as usual.
About to slap new box in so figured smart to replace starter if needed. But am leaning towards the relay path..
Try tapping (NOT HITTING :O ) your starter with a hammer or any other object with good inertial properties, give it a nice "tonk tonk tonk" sound. If it starts, then you need to replace the starter brushes, cheap fix too. From experience of three different vehicles having the same problem.
Sorry, misunderstood your description.
Probably just needs a service while the gearbox is out, I don't think it needs replacing. And make sure it has a good earth when you put it back together.
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
    • Did you pick up a manual cluster to remove the position indicator?  (Pretty sure the 34 has the gear position in the cluster, but it's been a while)
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
