R35 E85 Roll Call....
domino_z
 Share
Hey Domino
i use only sucrogen E85 in the big red drums. more expensive but 100% consistency in quality.
I only drive it on the track but the car runs/performs flawlessly
I have ID 1000cc injectors and Walbros
if anyone wants to see whats actually involved...
Diy injectors
http://www.speedfors...njectorsGTR.pdf
Diy fuel pumps
http://www.speedfors...KSfuelPumps.pdf
I'd go the Deutschwerks pumps instead of the HKS. http://www.speedfors...1.html?cPath=96 $338 vs $740 for the HKS and supposedly a drop in replacement as well. No happy about that bit with the HKS's about either having to grind the pump body or pump housing to make them fit :O. Would be interesting to see if you have to do the same with the DWs.
As far as Ethanol percentage goes I guess as long as you know what you've got in your tank whether it be 60% in winter or 80%+ in summer then I'm sure you can have a couple "intermediate" maps set up with your Cobb AP so you can select based on the mixture of your ethanol/petrol blend. It wouldn't be hard to knock up a simple dash meter to convert and display the PCM signal from a COTS flex fuel sensor to tell you what you've just pumped into your tank and select your map accordingly...If only the ECU could accept this input and do it for you! Or are you just better off just watching your fuel trims and selecting maps based on this?
That's good about the ECU reporting the correct flow rates as well Martin. I like the idea that the conversion doesn't leave you with small compromises such as losing some of the factory niceties such as accurate displays. Once the warranty is over I think this is a must do conversion!
Edited by fungoolie
Have any of you guys considered running 98 on the street and buying drums of E85 for the track? You can pickup a 200L drum for about $500 and its FAR better than the crap out of the pump they claim is E85
Why would you pay that much for E85? If the percentage of ethanol is important (for competition purposes) I'm pretty sure you can get 100% ethanol (4%? denatured) for just around a buck a litre and make your own E85 up yourself.
Edited by fungoolie
Fungoolie, contrary to the info supplied on the web the DW's are not a straight drop in replacement. I've had a couple of sets now (800cc & 1,200cc) and both times we've had to make some modifications to get them to fit correctly.
Cheers
Slip.
Cheers
Slip.
Oh so the injectors as well as the pumps arent direct replacements either? Thanks for the info Slip. Does anyone knopw of any injectors that just drop in? Or is there always going to be some mechanical or wiring adapter mods required?
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
