Not really. In my 3s-gte motor, when doing the buildup, I used the stock rods but replaced the bolts with ARP items. Doesn't mean the rods were no good or not up to the job, just meant that you could make them alot stronger by repalcing the possible weak point. Kind of the same thing here, I reckon.
i bought a pair of "OZSOME" 5-bolt ones they arrived yesterday $100 inc postage thanks again ebay.. :)
the bolts provided do really look pretty crap so i've taken one off to get measured up for replacement at my local QES.. most likely stainless with a flat washer will be going back in
the gears themselves are machined steel outer with a cnc machined alloy inner, the quality doesn't look too bad in all honesty, there is alot of meat in them and i can't see an obvious weakness just yet but will report once in use.. the contact area for the bolts to clamp down on is a full circle, which would indicate ALOT of torsion would be required to let it 'slip' out of its set degree position. the contact area where the belt would go doesn't have burrs/sharp edges or anything that would cause a mechanical failure of the belt.
the timing marking are also quite clear and finely laser engraved.
sure i wouldn't put these on my forged big $$ project, but mine is a clunker from back when paul keating was in power.. so i'm happy to give them 1/2 a chance..
Chris
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
