I have some spare parts for sale off my GTR. The car has under 100000 km's and was imported in 2006.
I have stock gearbox that i have upgraded and no longer need, It still works fine but i got an R33 one with stronger gears put in it. It comes with the transfer case but no shifter. $500.
I have a set of stock injectors, fuel rail and fuel pump that all work fine but have been upgraded and no longer needed. $250
I also have two APEXi blow off valves with the mount to suit a GTR. $200
I have pics of everything, if you want to know anything else let me know. Oh yeah pick up is from Thornleigh, Sydney.
I will take $400 for the gearbox as i don't have the room for it anymore.
I also have a PCM valve to suit an R32 GTR for sale for $50.
Hey mate was just wondering if you had any rear gtr Hubs that the driive shafts from the diff atttach to?
Have the following items for sale:
R32 GTR rear lsd/diff (pic for reference but is exactly the same)
$150
2 x R32 GTR dashes (1 really good condition with a small lift and one with ok condition with bubble infront of passenger)
$70/$30
Leather shift boot and handbrake
$20 for the Red/Black set
$10 for stock gear shifter
Pair of Recaro seat rails (1 Genuine, 1 not)
$150 for the set (will not separate)
  • 1 month later...
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
