Hey guys
So as the tittle states im building a S1 R33 but its a paticuarly centamentle build for me, five years ago my best mate passed away after crashing his S1 R33 at high speeds.
He faught for his life in hospital for some time and in the end passed away.
I never had much money but i vowed to myself to one day rebuild a exact replica of his car with an off trolley engine under the bonnet as a token of my rememberance to him.
He had a white 1994 S1 R33 Slammed on it ass with some awsome 18" wheels and some coil overs no engine mods at all.
Finaly I am in a position to be able to afford to build the car and so a few months ago i took ownership of a rolling shell that had been in a small mingel at a drift event, so now the build begins!
Ill post some pics during the week of the progress so far!
Cheers Gordon
https://www.sau.com.au/forums/topic/361567-in-memory/
Hey Guys Ive got all the photos together now.
Basicly A very good mate of mine Luke had a R33 setup as a drift car with rego had a RB27 combo in it and the car was killa, but unfrotunatly at one of the drift events in WA he had a small mingal with another drifter and decided to reshell the car rather than fix it and he was nice enough to donate the shell to me.
This was Luke at the event that wrecked the car
Once the pannels where removed it looked like a prity straight forward fix
Edited by REMANIS
https://www.sau.com.au/forums/topic/361567-in-memory/#findComment-5775114
So i set out trying to find a donner car to repaire mine with basicly needed and intire front end including the structural front clip.
I managed the track down an extremmely written off S2 R33 for $2,500 witch also had a low km RB25det and manual box so i grabed the write off!
You can see how big of a hit the R33 had taken by the fact that the side that didnt get hit was bent like a bannana LOL
Hit was enought to split the good side of the car open
https://www.sau.com.au/forums/topic/361567-in-memory/#findComment-5775130
There was an issue with the S2 i bought tho the front end was twisted so all the structural clip forward of the shock towers was no good.
Just in front of the strut towers is a factory join basicly you can drill out the factory welds remove the front clip and replace it with a new one.
So now i still needed to find a a good front clip.
The other problem was that it was a S2 and the car i was building a replica of was a S1 so i needed to swap front ends with some one witch i mananged o do recently.
I also managed to find a front clip with minimal damage!
It cost me $39 dollars and bit of time to cut it off LOL
Here are a few pics of how the car sits now!
Edited by REMANIS
https://www.sau.com.au/forums/topic/361567-in-memory/#findComment-5775166
Now that i had the shell sorted and booked intothe pannel beaters its time to sort out a Engine combo ith some balls.
First things frist we pulled the engine from the wreck
Then I begun looking for performance parts cheap because my budget is quite small and i did vry well here are all the parts ive purchased this far!
The turbo is a GT3071 with a .89 rear (I think its .89)
The mani is a 6Boost item with a 38mm Tial gate
The plenum is obviously a copy but its already been on a car and worked very well
The fuelrail is won of th old LUMPY rails LOL
The fuel system was already in the car but im not muh of a fan i think ill change it all to an in tank pump
So thats where im at
Cheers Gordon
https://www.sau.com.au/forums/topic/361567-in-memory/#findComment-5775195
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
