would i be able to get some advise on what to do with my bov? i just got it installed and its pretty loud, am afraid that it will get the cops attention. i am getting a plumb-back adapter for it, any opinions on that?
thanks!
go back to stock, even stock has a fair bit of noise with a pod/highflow filter
Does anyone have a 250-300rwkw gtst / gtt / gtr in Sydney who could take me for a brief spin in their skyline as I am also contemptlating putting on a hypergear turbo down the track??? I would really appreciate that.
Have a read of the nistune website. It lists a number of WA installers:
http://www.nistune.c...istributors.php
Also read the nistune thread on here.
The panel filters are a common size - falcon, evo etc.
I m using a Pipercross Px-PP1128 for about $100 there are K&N many others.
Use the search button and use Google to ask questions (quite often you will be referred to this website!).
may i ask where u bought ur panel filter from?
and also with my current pod filter, if i remove it and replace it with the panel filter, do i need any other adpaters or parts? cos when i bought the car, it already came with the pod filter, don't have the stock parts.
thanks!
Well I bought mine in Auckland so no use to you. You could order one from one of these Aussie suppliers: http://www.pipercross.net/fastroad/stockists_worldwide.asp?country=AU&id=9
From memory the afm bolts to the box and the hose fits the afm but since you have a pod now its not a priority tbh just look out for the bits at the right price when they come up.
Could I get some opinions on leaving out the bov entirely, covering up the valve and run it full surge back without any bov?
It will be noisy and depending on the turbo it can sound really shit or ok, can always block off your current bov so you know what it will sound like. Just make a gasket out of a coke can for now and see.
Edited by Rolls
dumps are the same according to a tuner I spoke to
neo has a different intake manifold, different sensors, ignition etc but exhaust should be identical
neo only came in the R34 afaik so 99% sure you have one
Edited by Rolls
cos im getting one and on ebay they're selling a RB25 one and a RB25DET one. Not sure which one to get.
Cheers!
Cheers!
odd, ask them to clarify before you buy, see if anyone in here chirps up as well, afaik they were all the same, maybe I'm wrong.
edit: oh right, 34 one is probably going to be different due to exhaust mounting etc, the actual dump flange is the same though.
Edited by Rolls
if you're going to upgrade the Turbo (why not when you can get stock like response but a heap more power) go for the Hypergear SS highflow - around 250rwkw and very similar response to stock. You'll prob need a Z32 AFM, but you MIGHT be able to get away with it. I maxed the resolution at around 240'ish rwkw on my old GTT.
You'll need a GOOD intake pipe made up as well if you switch turbos. The old 'shove a metal pipe in' has it's limits, you'll need something custom made up - DON'T go the silicone options, waste of time. Metal, metal, metal.
Injectors are a much easier deal now-a-days, just grab some Injector Dynamics injectors. Start around the 725cc mark, but i'd prob just get 1000's to allow for E85 :D Or get the 'no-name' variety of Bosch EV12 (i think) style injector, that's what the ID's are based off.
I went nistune, hypergear highflow, stock airbox, stock BOv, highflow panel filter, return flow IC (plus other supporting mods) for bout 5+ years with GTT - never any cops drama's at all. Make sure the exhaust isn't too loud, and following all the great advice already in this thread you'll have a mean car that's still quite stealth. 250rwkw in a GTT is a lot of fun :)
But please please look into your tyres/suspension/brakes as well.
Swaybars, do eeet! Cheap and fantastic handling upgrade - Whiteline.
Tyres, my car liked the KU36's, but alternatively i'd prob splash a few hundred more on some AD08's from tirerack
Brake cylinder stopper, check ebay, very cheap.
Check brakes over, bleed, put some good fluid in etc (RBF600)
But yeah, would be a good idea to check the spring rates if you can. Get some swaybars for sure though! :D
have fun
Both are rubbish imo..the outlet is only 2.5" on those style of dump elbows
Better off with something like this
http://www.skylinesaustralia.com/forums/topic/362300-why-are-my-tyre-marks-so-piss-weak/page__pid__5781686#entry5781686
They also have a stainless one
3" all the way through and bolt straight up to the cat
http://www.skylinesa...86#entry5781686
http://justjap.com/store/product.php?productid=17009&cat=276&page=2
what about this one? it doesn't say 2.5" or 3"
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
