So I'm planning on putting a pair of amps, one each side of the luggage area from the rear strut back (more like from where the cargo net hooks on the floor are). Well I'm trying to decide if I make the enclosed amp racks go all the way to the rear pillar or stop short where the tie downs below the pillar are, does anyone use them? What's your thoughts?
https://www.sau.com.au/forums/topic/361621-amp-racks-luggage-area-sides/
I put one amp under driver seat, and the other bolted to the back of the sub box in the boot, sub box can be unstrapped and lifted out so no loss of functionality, worked out sweet. Incase u think of it don't bother checking for space under the back seat u can't fit anything under there
ive got electric seats with a 2 channel under each front seat, so definitely room there but very close to seat motors. a lot more if not electric.
i had standard seats, ripped em out and converted to electric, so seen the difference.
for the cargo area, made a doughnut out of 16mm wood with about 30cm diameter and mounted a 2 channel to that which sits in my space saver wheel.
so all is hidden pretty much.
hopefully your amps dimensions aren't too big and the same spots are an option.
My linkSomething like this? But without the subs?;
Here's a link to the build thread - http://www.skylinesa..._1#entry4545242
I've since made a few adjustments, but they relatively the same.
Mine is an RS so no ATTESSA but it's only one bolt to remove to access the spot where one would be.
You don't really sacrifice any space this way either, and I can still carry a spare :thumbsup:
Edited by bayslideblue
