Well a change of circumstances calls for a change of vehicle so the Skyline is up for sale/swaps.
I was involved in a very, very light touch late last year and the car copped the lightest damage to the front right. The day after I had parked the car at the Hurstbridge train station (about 1100m from my house) and at 8:18 that night a copper drove through, saw the damage and left me a defect notice. It took an eternity to get the insurance sorted (through the guy who hit me) and in that time the rego was suspended (I wasn't going to fix it until I new it wasn't going to be taken by the insurance). So there we are.
1994 R33 GTS-T Coupe
Manual
~170k ks
$5500 ono or swaps for a 4 door r32/r33 GTS-T manual with cash your way if necessay.
Also interested in any other four doors or station wagons. Mush be interesting/turbo and manual.
Needed for roady -
  • Probably a front bar cover
  • Small amount of panel bashing the front right, or a new guard
  • Probably a windscreen (RWC mechanics tend to be a stickler for windscreens)
  • Front tyres replaced but only because they rub lightly on the inner guards (currently fitted are 235/45/17 - fine tread wise)
  • Grille - the damaged one could very easily be fixed though, like very easily.
  • Remove boost tee
  • It'll then need a bit of a general tidy up/panel beating to get everything to fit properly, but really not much.
  • I have 2 headlights to go with it. They are in excellent condition.
  • A couple of very small holes in the rear muffler patched
  • Will need a new battery.
If I think of anything else which needs mentioning, I'll put it up.
The good points!
The car is/was in excellent condition. It's been resprayed at some stage a very dark, metallic purple. Looks great although it's got a few typical scratches/chips on it.
Engine is perfect
Gear box is good, though syncros on 4th are shot. Apart from that it's very tight.
No creaks, rattles, squeeks from diff/suspension.
New Clutch
New rear tyres (chongshen specials)
Big FMIC behind the bar (stealth). Comes with pod filter AND stock airbox (currently fitted)
Comes with two excellent headlights and one good left
Good JVC headunit/speakers altho sub will be comming out :)
Interior very clean, straight and complete (apart from boot - a bitsa back there).
Been boosted to ~9PSI for about the last 2-3000ks of it's life. Stock boost always prior to that.
Starts first click, revs perfect, no smoke.
New radiator.
I love this car and will be sad to see it go, but I need a four door.
PICS TO COME
Call/SMS me on 0418 994 629
Car is located in Hurstbridge, north east of Melbourne. Can be viewed weekdays after 6pm and weekends (except fo rthis weekend!)
https://www.sau.com.au/forums/topic/361632-fs-r33-gtst-series-1-melb-4000swaps/
Righto, so crappy pictures as promised. I'll take some more at some stage when I have better light, and I'll give it a wash!
I'll include a Greddy Emanage Ultimate with harness as part of the deal. Not yet installed.
So $5k with the EMU + harness for a very good nick 33 which needs a tiny amount of work for roadworthy.
Going up on Fleabay tomorrow.
Will kick off at $3,500 with a $4,500 reserve.
If someone buys it here before I put it up I'll throw in the EMU and all and any spare I have here such as a full set of braided brake lines and whatever else I can find.
hi bro do u know what is exactly broken in the car?
There's a light bit of damage to the front right. It's cosmetic only, ie. the rad support and reo bar are untouched. You could either flatten out to guard on it now or pick up a astraight second hand one. Either job wouldn't be hard.
For roadworthy I predict it will need the following:
Battery
4 small holes in the exhaust filled, or a new rear section
possibly a new windscreen
probably front tyres as they rub on the plastic inner guards at full lock
horn reconnected
boost tee removed
an air filter for the stock air box
That should be it.
the car is straight, it's quiet, it starts perfect, first time, blows no smoke, revs perfect, pulls hard, brakes perfect and so on.
The only reason I'm not goign to fix it is because I need a 4 door for a potentially growing family in the not too distant future. And I also simply do not have the room to fix it. I live on the side of a mountain and don't have a garage.
Would u sell me just the emu
I will, if I sell the car. But for now I'll hang onto it in case I decide to hang on to the 33.
Check the gnew price.
$4,000 for a car requiring very little work for roadworthy.
Happy for people to come and inspect after ~6pm weekdays or on the weekend.
Gizza call on 0418 994 629 if keen.
$4,000 with the EMU.
Anyone?
I need a sedan! Interested in swapsies with cash your way. Keen on an R33/R34 4 door, XR6 turbo, XR8, must be manual.
Will go up to ~$12k your way depending on car.
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
    • Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
    • Would require a very smart body control module which these cars are about 20 years to old to have
