Double demerits til the 26th hey? The highway heading through Bunbury was really busy yesterday, all you perthies cutting through early. Also seen a few extra patrol cars on Old Coast Road so anyone heading down be safe
https://www.sau.com.au/forums/topic/361662-easter-weekend/#findComment-5772559
Yeah and the crap thing was I was in a Camry! lol
They only just nailed me, I was just probably a bit too tired and when the detector went off (as soon as they came into sight) I didn't get on the anchors quite fast enough :/
https://www.sau.com.au/forums/topic/361662-easter-weekend/#findComment-5781624
God damn DD! Got nailed for 15kmh over on the way home :( Oh well, first speeding fine in about 4 years!
Did you get caught by a hand-held or stand-alone one?
I nearly got done as well.
I took my V35 out on Tuesday evening. On Albany Hwy near Cannington area, I was on the right lane doing abit over 60km/h (Maybe 65-67km/h) in 60 zone. A Falcon ute drove past me on the left lane. After about 10 seconds, there was the white camera van parked on the side of the road (The one with the camera inside the car pointing from the back). I didn't see the flash. If it did, it would surely have flashed at the Falcon first. :P
https://www.sau.com.au/forums/topic/361662-easter-weekend/#findComment-5781685
luvpsi is that display pic you have taken at the carwash next to the liberty station on beaurfort street???
beeyow.
and bubba - that sucks man...
nah its on wanneroo road tuart hill that was the night i got her back from autoworx and she was filthy so i gave her a quick tub haha
https://www.sau.com.au/forums/topic/361662-easter-weekend/#findComment-5782079
I got done the day before the easter x2 points kicked in by some creep crouched down with a cam in some bushes on beach rd.I was boosting along doing 80 in a 70 zone i believe but we'll wait and see what grubby little bush lurker comes up with on his cam.
https://www.sau.com.au/forums/topic/361662-easter-weekend/#findComment-5782725
new cameras use infra red flash, cant see it
Oh f***. :(
I hope I will have to wait and see. I am pretty sure I was only doing 65-67km/h in 60 zone. Anybody know how many days do that fine take to get home through post?
Edited by VNS 24
https://www.sau.com.au/forums/topic/361662-easter-weekend/#findComment-5783111
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
