As mentioned last night at the meeting there is a Sandown track day being held by FFCC (Ford Four Car Club) in-between now and the next WRX event in July.
Sandown is great as it is close to Melbourne and generally within 30mins of everyone. Yes the walls are close to the track, just keep that in mind when
you press your right foot down.
Date
Sunday 8th May 2011
Price
$170
Requirements
CAMS L2S
CAMS club membership with current sticker (SAU VIC Membership)
Fire Extinguisher
Two bonnet latching mechs (the standard double latch is ok, but for older cars with the single latch no good you need a second with a tie down strap)
Blue battery triangle 150mm x 150mm x 150mm (get yourself some blue contact from the news agency and cut one up!)
Entry Form
http://www.ffcc.asn....0May%202011.pdf
Fill the entry in and post it off or email it to [email protected]
I printed it, filled the form out then took a picture with iphone and emailed it to them.
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/
  • Replies 93
Posted Images
lol what? Why didn't you just scan it to PDF and email it? i guess no access to a scanning device.... actually the photo thing isn't a bad idea! :D
Anyway I'll put my entry in after the Easter break, there's a few little things to sort out with the car before I enter. Decided not to do the Midland sprints at Winton the week before, this will give me more time to play around with the car :thumbsup:
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/#findComment-5773611
Yep it's a standard sprint day. Grouped according to estimated lap time (0 time if you are new).
I would suggest putting your lap time on the form under modifications, if you are new to sandown put that down.
5-7 12minute session
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/#findComment-5775375
http://www.alfaclubvic.org.au/content/view/195/79/
They run a pace car that exists the track with the next group behind it as the last car from the previous group crosses the finish line and does their cool down lap.
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/#findComment-5779759
Guest
    • Long time no see, I haven't posted since 14 years ago... To cut to the chase, R32 GTR. dead stock. Split wastegate hose = stock turbos were overboosting = front turbo's exhaust wheel has shattered. Have done a compression test following this and the results are (dry, cold) - 120 / 60 / 75 / 110 / 150 / 150. Haven't bothered with a wet test or leakdown test. The results definitely support front turbo failure (on 1-3) however the low compression on #4 is concerning too. Can anyone share their experience of when their turbine wheel shattered and damaged their motor - and what work needed to be done afterwards? Pistons? Rings? Valves? Throwing in the bin or salvageable? Motor is 100% stock. Will be getting it looked at further soon - I don't have a borescope and head hasn't come off (yet).
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
