As mentioned last night at the meeting there is a Sandown track day being held by FFCC (Ford Four Car Club) in-between now and the next WRX event in July.
Sandown is great as it is close to Melbourne and generally within 30mins of everyone. Yes the walls are close to the track, just keep that in mind when
you press your right foot down.
Date
Sunday 8th May 2011
Price
$170
Requirements
CAMS L2S
CAMS club membership with current sticker (SAU VIC Membership)
Fire Extinguisher
Two bonnet latching mechs (the standard double latch is ok, but for older cars with the single latch no good you need a second with a tie down strap)
Blue battery triangle 150mm x 150mm x 150mm (get yourself some blue contact from the news agency and cut one up!)
Entry Form
http://www.ffcc.asn....0May%202011.pdf
Fill the entry in and post it off or email it to [email protected]
I printed it, filled the form out then took a picture with iphone and emailed it to them.
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/
  • Replies 93
Posted Images
lol what? Why didn't you just scan it to PDF and email it? i guess no access to a scanning device.... actually the photo thing isn't a bad idea! :D
Anyway I'll put my entry in after the Easter break, there's a few little things to sort out with the car before I enter. Decided not to do the Midland sprints at Winton the week before, this will give me more time to play around with the car :thumbsup:
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/#findComment-5773611
Yep it's a standard sprint day. Grouped according to estimated lap time (0 time if you are new).
I would suggest putting your lap time on the form under modifications, if you are new to sandown put that down.
5-7 12minute session
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/#findComment-5775375
http://www.alfaclubvic.org.au/content/view/195/79/
They run a pace car that exists the track with the next group behind it as the last car from the previous group crosses the finish line and does their cool down lap.
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/#findComment-5779759
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
